跳转到主内容
加入维修社区 - 创建账户
2010年4月发布 / 2.4、2.53 GHz Core i5 或 2.66 GHz Core i7 处理器
screen backlight not working on MacBook Pro
One day my screen started flickering then it went black. I thought the lcd / led screen was dead but on further investigation (shining a light through the apple logo) I found that the screen is working fine its the backlight. Now I can not find a clear fix for this. Could I just buy a new screen and all will be well or is it something else I need to look at
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 17
3条评论
Hello ! Ifixit I got this problem when my macbook pro drop with open screen :( when I open it open with sound as normal but screen light a little bit like black !! so how to fix this ? do i have to change screen? sorry for my bad English :(
由完成的
When I switch on my MacBook Pro it gives light but soon the light goes off. I thought it was low battery. But, I discovered the system is on when I light by using external light (torch) when I put a password to login as well as normal but if you remove external light you don’t see anything on the screen.
Can any one can help me with this. Please!
由完成的
Back light not working. Bad screen had indeed a bad cable. Purchased new screen from iFixIt which seemed to be in order. Replaced screen but sadly didn't solve the problem. Now I can see something, but at the lowest brightness possible and brightness buttons don't do anything. Any help or suggestions are appreciated.
由完成的
添加一条评论
5个答案
已选择的解决方案
Your system uses LED's for the backlight system. On your main logic board is a driver chip (WLED) which likely blew.
Here's a simular question: Location of the WLED driver.
You may want to also review the IFIXIT teardown for your system: MacBook Pro 15" Unibody Mid 2010 Teardown.
这个答案有帮助吗?
得分 5
添加一条评论
最有帮助的答案
Do not forget to check your backlight fuse.
这个答案有帮助吗?
得分 7
2条评论:
Where is it?
由完成的
Here you find where is the fuse https://www.youtube.com/watch?v=HOhX95k-...
由完成的
添加一条评论
To know if it’s the backlight you can hold a flash light up to the logo on the backside of the screen if you see a faint image of your desktop icons then you know its the backlight or not.
这个答案有帮助吗?
得分 2
1条评论:
If you can see the image, does that mean it is your backlight problem?
由完成的
添加一条评论
https://youtu.be/HOhX95k-SxM screen backlight not working.
rossmann group is youtubes best diy mac repair
这个答案有帮助吗?
得分 1
添加一条评论
Here’s some images of WLED and backlight fuse locations:
Other answers:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
patrick 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 40
总计 171,729
