跳转到主内容
加入维修社区 - 创建账户
游泳池是一个装满水的容器,用于游泳或水上娱乐。
pump just hums
i have a summer escape pool and the pump just hums what can i do to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
KATHY, there are a few possibilities. Chance of a bad motor start capacitor ( use a multimeter or capacitance meter to check that) a seized pump motor (unplug the pump and see if you can turn the impeller by hand) or a short on the start winding of your motor. We could possibly give you a bit better info if we would know what make and model your pump is. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
The pump has a tiny plastic fan blade which moves the water thru the pump the blades in your fan are broke replace the punk
由完成的 分享
bang on the motor with a hickory stick, it that doesn't start it, it is the capacitor, replace or bearings, then have to replace the dry end or motor. 35 years in Biz
由完成的 分享
添加一条评论
Most likely is a bad pump motor start capacitor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KATHY 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 919
