跳转到主内容
The iHome iH5 is a plug-in speaker accessory for Apple's iPod and iPhone, released July 1, 2005.
Why is my iPod not connecting through the docking cradle?
Whenever I plug my iPod through USB cable it will connect to my computer, but my iPod will not connect to the iHome. It will not even charge. Do i need to replace a part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
What model iPod do you have and has it ever connected to the iH5?
完成的
添加一条评论
2个答案
已选择的解决方案
Steven Smalley, you did not tell us what model iPod your are using. You will have to make sure that your iPod is compatible with your iH5.
iPod Shuffle NOTE: iH5 will not charge iPod Shuffle
iPod Mini
iPod 3Gen 10-15 GB
iPod 3Gen 20 GB
iPod 4Gen 20 GB
iPod Photo 30 GB
iPod 3Gen 30 GB
iPod 3Gen 40 GB
iPod 4Gen 40 GB
iPod Photo 40 GB
iPod Photo 60 GB
iPod nano 1 GB
iPod nano 2 GB
iPod nano 4 GB
iPod 5th gen Video
anything else will not work due to a reconfiguration of the dock connector. If you are connecting one of those iPods and still have issues with that, replace the dock connector on your iH5. You'll find some good instructions for that on here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
You may have to replace the docking cradle, but another solution could be bad wiring, or the iHome itself may not be recognizing the iPod, as is a common issue with this model. The iH5 doesn't charge certain devices such as the iPod Touch, but may still play with it.
这个答案有帮助吗?
得分 -1
1条评论:
William, how do you do that "replace the docking cradle"? How do you check the wiring? Why is this "a common issue with this model."? Why would it not recognize certain models? You are guessing and not providing solid answers.
完成的
添加一条评论
添加你的答案
Steven Smalley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,796
