跳转到主内容
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
top lid wont unlock
lid wont unlock will not start wash cycle
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
8条评论
Sarge, are you saying you can not unlock the lid? Or that the lid switch does not work? does your lid open?
完成的
lid will not open. lock will not release.
完成的
I have this same problem and my washer is almost new. Had nothing but trouble out of this washer since I purchased it and will NEVER have another. Anyone know if there is a warranty on this thing? I didn't purchase the extended warranty because it was a huge percentage of the washer's price and didn't last long.
完成的
I have left the washer unplugged all night and the red light is still on and the lid will not unlock I am very upset with this washer I have had nothing but problems out of it making clicking noises and you sure can’t put very many clothes in it at a time to wash
完成的
I bought this Kenmore washer July 2013 and have had nothing but problems. Never again. Trying to open lid is a pain. Here I thought I was doing good for environment to save water with a sensor. No repairman can get here for one week. It sounds like Sears has an issue with washers. Never again. My first time tomorrow using a laundromat (however you spell it) since my last one broke down July 2013
HygHydy@aol.com
完成的
显示更多的3条评论
添加一条评论
4个答案
已选择的解决方案
Main Control Board
If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Unplug the machine for 5 minutes to let it reset and then plug it back in and give it a try.
这个答案有帮助吗?
得分 6
6条评论:
I can't fix anything and can't afford having it fixed. This worked for me, and I'm so grateful! Thanks!
完成的
Tried this it didn't work. I had the same problem as the previous person.
完成的
New washer used once then this second load it was locked the night after it was bought. Lid won't open tried to unplug Sears is coming out Wednesday we need clean clothes help. Towels are sour.
完成的
Washer lock lid is broke and cant get the washer to work now. It keeps making a clicking sound?? How can i fix this
完成的
Washer won’t unlock, I unplugged it for 5 minutes, then plugged it back in and it still won’t unlock.
完成的
显示更多的1条评论
添加一条评论
unplug for five minutes …if still locked push start button for a few seconds and it should unlock. Like cancelling your wash load.
这个答案有帮助吗?
得分 0
3条评论:
Just 2 days of using my machine and it the lid.lock. tried to unpluck it do several times but still doesnt work
完成的
kenmore washing machine series 100 lid wont unlock repairman came out said have to replace lid $100 and labor $40 or more plus tax....
完成的
plus a $79 service fee charge to repairman we had to pay
完成的
添加一条评论
Fixed this issue by power cycling the AC breaker! It worked like a charm. Needed a main AC reset.
这个答案有帮助吗?
得分 0
1条评论:
Well how the &&^& do I do this
完成的
添加一条评论
Me funcionó la conchadetumadre vales oro gracias :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarge 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 36
过去 30 天: 153
总计 72,244
