跳转到主内容
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
What is the battery model number?
Did you find out what model battery the 4th gen Aiport Extreme uses? Would be helpful to list as part of the required tools/parts.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
rockja, looks like a panasonic br2330
这个答案有帮助吗?
得分 2
添加一条评论
my airport extreme got dead no lights nthn. tried to change the as well but still it remain the same .. help me
这个答案有帮助吗?
得分 0
添加一条评论
The battery is only for the memory/BIOS settings for the device.
The unit runs on a 12vdc adapter. Check the output of your adapter with a meter and verify the voltage marked on it.
There is probably a SMT fuse on the board near the plug. It should be labeled "F1" unless there is more than one fuse. You could check to see if that is blown and replace it if you have a solder iron. Set the meter to OHMS and touch a probe to either side of the device. A good fuse will show 0 ohms.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rockja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 445
