跳转到主内容
加入维修社区 - 创建账户
本田汽车的维修和支持指南。
Car jerks while accelerating.
My 2002 Honda Accord with 82500 miles on it jerks a bit when accelerating. Nothing happens to the speed but the rpm drops and then again increases and then the car picks up speed. What might be the problem ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
13条评论
what engine size is in your Accord? Any change in gas mileage? When was the last service?
由完成的 分享
The engine size is 2.3L 4Cyl., I haven't really looked at the gas mileage. The last service was done in May when the car had around 80K miles and now the car has around 82.5K miles.
由完成的 分享
Could i buy a transmission with a 2 year warranty and have it installed?
由完成的 分享
My hunda car won't pick up as I engaged it into drive mood even when i matched down the acceleration pedal. What might be the cause?
由完成的 分享
i have the same problem how did you fix it ?
由完成的 分享
显示更多的8条评论
添加一条评论
6个答案
已选择的解决方案
Could be a knock sensor or a loss of air inside the air box/tube that goes to the intake manifold. I would have the check engine light checked; just because it isnt on doesn't mean there isn't a code in the system. Most of the errors would give you a check engine light, so it might just be a matter of time till it comes on.
My Subaru had a faulty knock sensor => loss of power when accelerating
Mazda had a break in air duct => loss of power when accelerating
这个答案有帮助吗?
得分 4
1条评论:
Yeah I got the knock sensor code and p0502
由完成的 分享
添加一条评论
Change the ignition coils and your problem will be fixed .Before changing coils insulate them by pvc tape
first and install them back in and if you problem decreases it will be confirmed ignition coils are bad now .so just change them .
这个答案有帮助吗?
得分 2
1条评论:
My 2005 Honda pilot jerks when I take off on freeway and after shifts fine runs good some days I have to turn off because blinking lights like the D and a ! I turn off then on and it's fine what can it be
由完成的 分享
添加一条评论
The Driver ? Joke LOL
I would start with New Plugs / Oil/Air/Fuel filters. is the check engine light on ?
这个答案有帮助吗?
得分 1
1条评论:
No the check engine light isn't on.
由完成的 分享
添加一条评论
my Friends Car was like that.. It would have almost NO power also.
it was the O2 Sensor that went bad and needed replacement.
weird eh?
这个答案有帮助吗?
得分 0
5条评论:
Hi my 2000 Honda Accord is jerking when I take off from sitting still I step on the gas and it jerk pretty hard then it drive I come to a red light it stops and when I get ready to go it jerk what can this be my car has almost 100000 thanks for any info
由完成的 分享
What does the belt look like?
由完成的 分享
Mines does the same thing it starts blinking D and a ! I pull over turn it off turn back on and it runs fine after that what can it be
由完成的 分享
Speed sensor
由完成的 分享
@Lewis Johnson speed sensor
由完成的 分享
添加一条评论
Had the same problem changed airfilter in Honda civic ex 56plate sorted
这个答案有帮助吗?
得分 0
1条评论:
i have honda civic 2006 d light is blinking and car is jerking when it comes to stop sing
how did you fix your car ?
由完成的 分享
添加一条评论
speed pick up problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
neha 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 93
总计 92,570
