跳转到主内容
加入维修社区 - 创建账户
门窗的维修与拆解指南。
How to install a window to replace AC unit?
Hi Folks,
Finally got around to removing a heavy old built in Air conditioner unit from my living room.
http://flic.kr/p/ggN4a9
I'd like to install a window that can be opened to let the breeze flow. Could anyone let me know where to start?
Thank you!
Jacob
Update
Thanks for the support so far. Working on removing the metal frame the air conditioner was housed in this morning. At first nice and quietly with the bolt cutters as not to disturb the neighborhood. Then, more successfully using the angle grinder to cut away the box.
http://m.flickr.com/#/photos/slugworth/1...
Update
The opening is roughly 26.5 by 18.5.
Here is a view from the outside.
And a look from inside.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
How about a photo from the other side?
完成的
Jacob, couple more pics will definitely help. BTW love the architecture, real brisk and a solid wall, excellent!!!!
完成的
Jacob, that is a definite ifixit job:-) Keep us informed about your progress. Still wondering what the window opening looks like from the inside and outside with the AC removed. what are the dimension of the opening?
完成的
The base of the AC unit was resting on the roof below. Some tar was keeping it in place. I used a crowbar aka "Sparticus" to pry up the final pieces.
完成的
添加一条评论
2个答案
已选择的解决方案
Jacob, great demolishing job:-)! anyhow, at this time you will have to repair the brick work in the opening. Use what looks like a top beam in your pictures as the lentil. Get some pressure treated lumber and fasten it with anchor bolts around the window opening. That will give you something to mount the new window to. I would check sites like this for installation instruction. Of course, not knowing where you live, you also want to make sure that you have proper drainage away from the window etc. Follow your local building code. It is a relatively small opening, so keep the framing reasonable. The attached images shows how it should be done:-)Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Do a Google search for transom+window and images for some ideas.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jacob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 36
总计 5,015
