跳转到主内容
The Dell Inspiron 15 (N5050) is a mid-sized laptop manufactured by Dell, Inc. that operates on Windows 7. The laptop features include a WLED HD display screen and a max supported memory of 8 GB.
20 个问题 查看全部
My dvd drive was not working can I replace it
my dvd drive was not working offcourse cd drive was working.so please suggest me how to repair it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
anusha, this could be caused by misaligned/dirty lasers or bad diodes. You could try and clean the drive with some commercially available lens cleaner. If that dos not work, you may have to replace the drive. To see how to replace the optical drive, use this guide. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
You can open the CD rom tray and use a alcohol swab or use perfume on some non static sponge to carefully clean the lens. Hopefully your Rom shall start working if not then you might need to replace it. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anusha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 427
