跳转到主内容
加入维修社区 - 创建账户
HTC One(代号 M7)是 HTC 2013 年的旗舰智能手机。它采用无缝的一体成型机身设计、双前置扬声器,并配有一块 4.7 英寸 1080p 显示屏。
How to fix the cracked screen?
My screen isn't shattered per say but it has a crack at the point of impact. Then the cracks become less visiable as it goes away then leads to the end of the screen. I know that it is nearly impossible to get inside of the HTC One much less fix the screen. Any help would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Thanks i'll let you know how it goes
完成的
添加一条评论
2个答案
最有帮助的答案
Connor Dempsey, use this teardown to give you an idea of what is involved. The display assembly isright here. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
4条评论:
not quite sure why this was voted down. Just because somebody does not like it, does not make it a wrong.
完成的
alcs99 gave you the down vote. I'll up vote to cancel.
完成的
Thank you Sir. Not quite sure why alcs99 would do so. I would appreciate if people would at least say why they downvote an answer.
完成的
No disrespect guys! In my comment I hope I explained it well enough why I gave this comment a down vote. The iFixit staff's method of pulling it apart is not the way to do it and in my guide I show the correct way to do it. Much love and keep on fixing!
完成的
添加一条评论
Do not follow ifixit's teardown, the method they used to open the phone to get at the internals is not the best way to do it. I posted a guide on repairing the screen with links to videos on how to properly open the phone and remove the back cover.
HTC One 显示屏组件更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Connor Dempsey 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 20
总计 9,937
