跳转到主内容
Disappointing performance gain from increased RAM
I recently upgraded the extra RAM DIMM in my 800 MHz iBook G4 from 512mb to 1gb. I'd been hoping for a big performance bump, but I haven't really noticed much of a difference. I'm just curious if anyone has had a similar situation and if there might be something I'm failing to do to take full advantage of the additional memory.
The memory does show up in the System Profiler (128mb built-in plus the 1 GB DIMM).
I'm currently getting a 22.04 Xbench score. I tested before I upgraded the memory, but unfortunately didn't save those results. But I'm vaguely remembering a score of 19 or 20 with the 512mb DIMM.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
in the real world?
is the computer faster doing stuff you want?
less beachballing?
I mean. it s still the same computer, but the extra memory will mean less swapping ....
完成的
When I'd done memory upgrades on other computers in the past, everything immediately felt snappier. This time, not so much. The computer feels as draggy as ever, particularly on the internet.
完成的
添加一条评论
4个答案
已选择的解决方案
The best performance gain to be had in an iBook is to replace the harddrive - Apple Shipped iBooks with 4200 RPM Drives! slap a 7200 RPM drive in, night and day.
这个答案有帮助吗?
得分 1
2条评论:
There's an idea! But I'm looking at the ifixit guide, and this looks like a pretty formidable undertaking. Before I start, I'm wondering if I can get a sense of how much faster the machine would run by starting up from a 7200 rpm external firewire harddrive. Do you think that would approximate the speed of the computer with a 7200 internal hard drive?
完成的
You might get a bump, but you've already spent money, a HD will cost more plus labor, and the increase is just not going to be too dramatic. Whereas if you sell the computer for $200 on eBay and buy a 1.83GHZ MacBook for $450 on Craigslist, the $ won't be much more, yet you'll have a way more powerful machine that will last years. If you're looking at this as a fun project, that's awesome and I say go for it, but if the goal is to get done with this and use your computer, go with a MacBook.
完成的
添加一条评论
最有帮助的答案
You didn't mention what OS you have on this machine, but I wanted to mention that there is a huge difference between the performance of Tiger 10.4 vs Leopard 10.5 on a machine of this speed. Tiger does not require the same resources as Leopard, so if you have Leopard installed, you may want to downgrade to Tiger, and you may get at least part of the speed increase you're looking for.
Besides that, unfortunately this is an old and relatively slow laptop that isn't getting any faster, so you may want to consider upgrading to a used MacBook in the $500 range, which will be a night and day difference in terms of performance.
这个答案有帮助吗?
得分 2
2条评论:
I'm actually using 10.3.9. Do you think Tiger would be faster?
完成的
I haven't used 10.3 in ages so I'm not qualified to say, but I would guess 10.3 would use even less resources than Tiger and probably be even faster. I think what it comes down to is if you need significance performance increase, a new computer is in order. Memory helps, but is only one factor, i.e. putting new sport tires on a Honda Civic does not make it a Ferarri. :-)
完成的
添加一条评论
For what it's worth, I upgraded RAM in a PowerBook G4 12" 1.5ghz (I think it was 1.5ghz) to 1.25GB when I upgraded to Leopard. I didn't notice much of a performance difference either, anecdotally. I agree with rdklincorporated's advice
这个答案有帮助吗?
得分 2
1条评论:
Thanks -- at least it's nice to know I'm not the only one!
完成的
添加一条评论
1GB still isn't that much, I myself only have 1 gig on my MB, and that can barely do anything. Added to the rather slow processor you have, I wouldn't expect much.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mister790 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,592
