学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Table of Contents
Camera Will Not Turn On
Battery is not Charged/low
Battery is not Working
Charger is Faulty
Motherboard is Faulty
Battery not Inserted
Short Battery Life
Remove the Battery Pack
Lens is Blurry/Hard to see out of
Clean the Lens
There is a Crack on the Lens
Image Distortion
Replace the CCD Sensor
Cracked LCD Display
Replace the Screen
Camera Freezes or Device is not Being Recognized by the Computer
Replace the Motherboard
Symptom: Camera will not respond when pressing the on button.
Camera batteries don't last forever. The average life of a camera battery is 250 pictures. If the battery is rechargeable, use the battery charger to power up the battery. If it is not rechargeable then replace the battery with a new one.
If you have already charged the battery then something is wrong with the battery and it needs to be replaced.
Charger is Faulty
There could be a issue with the charger and the device could be broken. Use a different camera that uses the same battery or use a similar charger to power the battery then see if it turns on the camera. If this does not work, then the charger is broken. You have to replace the charger.
If the battery and charger are working but the camera still does not turn on then there an issue with the motherboard. You would need to replace the parts.
Battery is not Inserted
Make sure before you try to turn on the camera that the battery is inserted in the side slot of the camera.
Short Battery Life
Symptom: A green LED light will blink repetitively if a charging problem exists with the camera. Most often the charging issue exists because the battery pack is too hot or too cold. The battery should be brought to room temperature before charging. Also is the battery is 100% discharged, the blinking condition will subside after 10-15minutes. If this issue persists, then the battery pack (DMW-BCK7) should be replaced.
If the camera repetitively dies quickly and/or is not holding a charge, then most likely the old battery pack will have to be removed and replaced.
Symptom: Pictures taken come out looking like somebody smudged them.
Clean the Lens
If the pictures seem blurry on the LCD display when you take a picture, try cleaning the lens with cleaning wipes.
There is a Crack on the lens
If there is a crack on the lens or the lens is shattered, then you have to replace the lens.
Image Distortion
Symptom: One source of your picture having strong tints or color casts, a series of strange lines running across images, and/or image distortion in general can be from a broken CCD (charge coupled device) sensor.
If the pictures you are taking appear to suffer from any of the above symptoms, the root cause is most likely from the CCD sensor. Since a sensor is a complex component the best solution to a faulty one is to remove the old one and put a new CCD sensor in its place.
Cracked LCD Display
Symptom: Cracks across screen, faint lines on digital display, patches of the image are lost (pixels missing), or black screen (nothing appearing).
Replace the Screen
If the screen is cracked or any of the above symptoms exist most likely the best option is to have the broken screen replaced with a new one.
Symptom: Most likely is the camera suddenly freezes or in the case it is connected to a computer and is not being recognized, an internal hardware issue exists.
Although this can be a costly expense the Motherboard would have to be taken out and replaced if the above symptoms persist.
1条评论
Hello. The audio portion of all of the videos I’ve taken have deteriorated to the point that they are inaudible. I rarely use the camera so why has this occurred and how do I resolve this issue so that I have an audio track to my videos? I purchase the camera in 2012 but I virtually never use it. The few important videos I’ve taken in 2012 and 2013 have a grossly deteriorated audio tract that has been rendered inaudible. What’s the fix? Thanks.
Jake - 回复
