跳转到主内容
目录
学生贡献的维基
此维基页面由我们教育项目的学生团队编写。
Asus Memo Ribbon Cable
Images will be distorted or not show up at all.
Replacing ribbon cable
It is possible that it appears nothing is happening, because the cable bundle is in need of replacement. If replacing the battery and screen fails to fix the tablet not turning on, then you may need to replace the ribbon cable using this guide: Asus MeMO Pad 7 ME170C Ribbon Cable Replacement
Asus Memo Pad 7 Speaker
There is no sound or not at right level
If tablet has no sound
If your speaker will not produce sound, you can check to make sure the volume settings on the tablet are correct. If that fails to solve the issue, than replace the speaker using this guide:
Asus MeMO Pad 7 ME170C Speaker Replacement
Sound is not at desired level
If sound isn't at an appropriate level, locate volume buttons on upper right hand side. Push the upper portion of the button to increase and lower portion to decrease.
Asus Memo Pad 7 Battery
The device will not power on
Will not turn on
Your tablet will not turn on because your battery is dead. Charge the battery of your tablet by using a micro USB cable. Plug one end of the cable to the appropriate port located at the top of your tablet and plug in the other end to a computer or outlet converter that is plugged into a working outlet in the wall.
Replace Battery
Your tablet will not turn on because your battery will not charge. In this case, you must replace the battery. Follow this guide to replace damaged battery:
Asus MeMO Pad 7 ME170C Battery Replacement
Asus Memo Pad 7 Microphone
''When your tablet does not record sound"
Replace
The mircrophone allows you to input sound for voice commands or record voice memos, or talk to text. If your tablet is unable to input sound, here is a guide to replace the microphone:
Asus MeMO Pad 7 ME170C Microphone Replacement
Asus Memo Pad 7 Mother board
Operating system will not work
Hard reset
If system crashed, then a hard reset may be required. Push both volume buttons and power button, all located on the upper right hand side, hold for 10 seconds.
Take out and Replace
After replacing the battery and a hard reset doesn't work, then it will be necessary that the motherboard needs to be replaced. Use this guide to do so:
Asus MeMO Pad 7 ME170C Motherboard Replacement
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,960
