跳转到主内容
Asus MeMO Pad 7 ME170C Motherboard Replacement
你所需要的
  1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 步骤 1 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 步骤 1 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 2 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 2 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 2 中的图像 3,3
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 3 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 3 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 3 中的图像 3,3
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 4 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 4 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 5 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 5 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 6 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 6 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 6 中的图像 3,3
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 7 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 7 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 7 中的图像 3,3
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 8 中的图像 1,2 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 8 中的图像 2,2
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 9 中的图像 1,2 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 9 中的图像 2,2
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 10 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 10 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 10 中的图像 3,3
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 11 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 11 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 11 中的图像 3,3
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 12 中的图像 1,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 12 中的图像 2,3 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 12 中的图像 3,3
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 13 中的图像 1,2 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 步骤 13 中的图像 2,2
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
结论
6等其他人完成本指南。
一条评论
You are amazing!! Please make the tutorial "how change ASUS ME170 Touch Screen Digitizer". Thanks!!!
Walter Tejerina - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 3,353
