跳转到主内容
Ring ring! Ring ring!
Your cell phone rings. You know you should answer it, but it's all the way in your pocket, and the thought of reaching down, pulling it out, tapping a button, reaching up to your ear, and talking just sounds plain exhausting. But never fear! Samsung comes to the rescue.
Introducing the Gear 2, Samsung's revamped smartwatch. Join us as we tear down the future of wearable tech and attempt to answer the question: can a device be smart, wearable, and repairable?
Only time will tell…
Stay on time with the latest teardowns and developments by following us on Instagram, liking us on Facebook, or tweeting us on Twitter.
你所需要的
工具
查看更多...
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的Samsung Gear 2,应参考我们的维修指南
  1. Samsung Gear 2 Teardown, Samsung Gear 2 Teardown: 步骤 1 中的图像 1,2 Samsung Gear 2 Teardown, Samsung Gear 2 Teardown: 步骤 1 中的图像 2,2
    • One of this gadget's most innovative features is that, at any moment, you can look at your wrist and know the exact time. Phenomenal.
    • Other tech specs include:
    • 1.63" Super AMOLED display (320x320 pixels)
    • 4 GB internal memory
    • 2.0 MP camera with 720p video at 30 fps
    • 300 mAh battery (2-3 day battery life)
    • Bluetooth 4.0 LE
    • For fun, we removed the band and weighed this little timepiece: 41 grams (less than 33% the weight of a Rolex Daytona—in the tech world, we're pretty sure that makes it three times better).
  2. Samsung Gear 2 Teardown: 步骤 2 中的图像 1,2 Samsung Gear 2 Teardown: 步骤 2 中的图像 2,2
    • Once upon a time, smartwatches were only for superspies and TV heroes.
    • Despite all the tech underneath, the Gear 2's only visible gadget is its 2-megapixel camera, nicely nested into the brushed metal surface.
    • Samsung's 1st-gen Galaxy Gear housed its camera in the wristband—a less-than-ideal setup that made for a less-than-replaceable band. This new location is a good sign.
    • The main issue we see with this design is that having a camera constantly facing away from your body makes selfies nearly impossible.
    • Is this a fatal flaw of the Gear 2? It's a bold strategy, Samsung; we'll see if it pays off for 'em.
  3. Samsung Gear 2 Teardown: 步骤 3 中的图像 1,3 Samsung Gear 2 Teardown: 步骤 3 中的图像 2,3 Samsung Gear 2 Teardown: 步骤 3 中的图像 3,3
    • Our Gear 2 may not be spy-issue, as it still exhibits identifiable markings: Model No. SM-R380.
    • The backside bears a row of contacts for the cradle charger, as well as a teeny tiny sensor. More on that later in the show.
    • Before we even begin searching for a way into this quintessential smartwatch, a quartet of quaint Torx screws catches our quizzical eye.
    • Screws are good news. Glue makes us blue. Could this device be a repair enthusiast's Xanadu?
  4. Samsung Gear 2 Teardown: 步骤 4 中的图像 1,2 Samsung Gear 2 Teardown: 步骤 4 中的图像 2,2
    • Ejecting removable wristband in 3…2…1…
    • Free at last! A replaceable wrist strap is a right, not a privilege. We're glad to have the opportunity to change a band up a bit.
    • A band is likely to break up—er, show some wear and tear over time. It is nice to know that no matter how much time has passed, this Gear can always get back together.
  5. Samsung Gear 2 Teardown: 步骤 5 中的图像 1,3 Samsung Gear 2 Teardown: 步骤 5 中的图像 2,3 Samsung Gear 2 Teardown: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    • Here it is—the moment of truth is upon us. Will this device truly be smart, wearable, and repairable?
    • Oh my flying spaghetti monster! We cannot believe it! Just look how beautiful that opening pick is. If that doesn't make you want to smash a 20 minute air guitar solo, we don't know what will!
    • Side note: the Gear 2 came apart extremely easily. A small Torx driver and a bit of light prying split this watch in half with ease.
    • "No cables, no problems," that's what we say. The halves communicate solely via spring contacts.
    • Never before has a device been so repairable that it comes pre-loaded with markup.
  6. Samsung Gear 2 Teardown: 步骤 6 中的图像 1,2 Samsung Gear 2 Teardown: 步骤 6 中的图像 2,2
    • The battery springs willingly from its seat, with help from an instructional pull tab.
    • The Gear 2 is slowly winning us over with this repairability business. Samsung, you may continue wooing us.
    • Samsung claims the 300 mAh battery is good for 2-3 days of normal spying use. Charge cycles are a huge factor in Lithium ion battery health, so a multi-day charge makes us happy to see.
    • The quartermaster would like the equipment returned with a full charge, please.
    Do you know the voltage of the battery? Where can I buy a battery like that?
    Alex Dein - 回复
    It seems to be a standard Li-Ion cell, between 3.4 V and 4.0 V (3.7 V average), since it is charged by a normal USB supply of 5 VDC.
    rayramirez -
    Great. Where can I purchase a replacement battery? After less than a year, my battery will discharge completely overnight while turned off, and will discharge from 100% in less than 4 hours when turned on with Bluetooth off.
    BC - 回复
  7. Samsung Gear 2 Teardown: 步骤 7 中的图像 1,3 Samsung Gear 2 Teardown: 步骤 7 中的图像 2,3 Samsung Gear 2 Teardown: 步骤 7 中的图像 3,3
    • This watch makes us feel a little like a certain inspector… Let's take a closer look at some components.
    • Go, go, gadget speaker! Out goes the music/speakerphone speaker, simply secured with light foam tape.
    • The repairability of this device impresses us more than another inspector in a bright red blazer.
    日本語
    この、プラッチツク黒カバー
    ステンレスカバーありますか⁉️
    roboconpo - 回复
  8. Samsung Gear 2 Teardown: 步骤 8 中的图像 1,2 Samsung Gear 2 Teardown: 步骤 8 中的图像 2,2
    • Gasket lining the case: check.
    • Gaskets around the screws: check.
    • This modest arrangement is enough to garner the Gear 2 its IP 67 certification, making it safe for immersion in up to 1 meter of water for up to 30 minutes.
    • Underwater teardowns are not yet an approved part of the iFixit repairability scoring process. Stay tuna'd tuned.
    Where to buy this charging connectors
    Nandha kumar - 回复
    hi where can I buy the blue/green charging connector piece in the back cover as seen in this picture?
    oliverkuo - 回复
    Hi i need charging board SM-R380 REV0:3
    Suburathinam - 回复
    plz tell me the web address to buy the samsung gear 2 charging boar SM-R380 REV0:3
    Suburathinam - 回复
    I too require the 5 pin charging board. The charging cradle took one of the five plates right off and now the watch is a brick.
    Omalley177 - 回复
    Hi would like to know where to get charging contacts as well. one of mines have been destroyed and Samsung not interested as they say it is damage. Sweat must corode the contacts as rest are pitting.
    user1701e - 回复
  9. Samsung Gear 2 Teardown: 步骤 9 中的图像 1,2 Samsung Gear 2 Teardown: 步骤 9 中的图像 2,2
  10. Samsung Gear 2 Teardown: 步骤 10 中的图像 1,2 Samsung Gear 2 Teardown: 步骤 10 中的图像 2,2
    • The LCD and digitizer connect to the motherboard via a single cable, which also serves to hold the board in, like a cute little seatbelt.
    • With the connector out of the way, the board is free to roam, with all of its efficiently-packed peripherals strapped in for the ride.
    • A few non-modular components are soldered to the board: IR LED (for TV remote functionality), heartrate monitor, and vibrator motor.
  11. Samsung Gear 2 Teardown: 步骤 11 中的图像 1,3 Samsung Gear 2 Teardown: 步骤 11 中的图像 2,3 Samsung Gear 2 Teardown: 步骤 11 中的图像 3,3
    • Small package, lotta power:
    • Samsung KMF5X0005M (likely DRAM package with 1 GHz dual-core CPU layered beneath)
    • Motorola MPS14X 60X5V3 1410WeC
    • Maxim Integrated MAX77836 Low-Voltage Input, 3V/3.3V/5V/ Adjustable Output, Step-Up DC-DC Converter
    • STMicroelectronics STM32F401B ARM-Cortex M4 MCU with 128KB Flash
    • 0225E8 E225B4
    • BCD Semiconductor Y831 audio codec
    • InvenSense MP65M 6-axis gyroscope / accelerometer
  12. Samsung Gear 2 Teardown: 步骤 12 中的图像 1,3 Samsung Gear 2 Teardown: 步骤 12 中的图像 2,3 Samsung Gear 2 Teardown: 步骤 12 中的图像 3,3
    • We can't help pushing the buttons of manufacturers—and Samsung is no different.
    • We tweeze off the home button assembly, followed by its good, old-fashioned mechanical button.
    • We've reached the end of time. All that remains is the fused back of the display assembly.
    • While we're sad to see this (relatively) large component fused, we're happy to know that a spiderwebbed display would be reasonably fixable by simply replacing the entire display assembly.
    • The teeny tiny touchscreen is powered by a Melfas touch sensor chip.
    How can I order the home button
    Carlos Gonzalez - 回复
    I'm in need of screws/fasteners...
    the ones located where the silver clasp connects to the wristband. The 2 screws came out unbeknownst to me when it happened?!
    Advanced Thanks...
    STRONGBYD@AOL.COM
    ALSII - 回复
    Same exact thing happened to me, havent had the watch for more than 6 months.. not sure where to get the screws for the clasp either. about to see about a replacement through samsung
    strike85 -
    I'm in need of new contacts the under part of the watch has a faded contract that helps it charge whet can I find a replace ment?
    raulomccomono - 回复
    Did you find them yet?
    David Dalby -
    Hey did you ever get a lead on finding where you can get new contacts?
    Alex Herrera -
    My tiny screws fell out of my watchband fastener....no idea where they went.
    I wasn't able to find anything online, so I just went to DollarTree and bought their eyeglasses repair kit for $1. There are a variety of tiny screws in the kit (and screwdrivers), and I used a pair of tiny screws that fit the holes. They are a tiny bit too long, but they don't touch your skin because they are covered when the band is in place.
    bama mom - 回复
  13. Samsung Gear 2 Teardown: 步骤 13 中的图像 1,2 Samsung Gear 2 Teardown: 步骤 13 中的图像 2,2
    • Samsung Gear 2 Repairability Score: 8 out of 10 (10 is easiest to repair)
    • The watch band is super easy to remove, speeding replacements and upgrades.
    • Screws, clips, and spring contacts make up the trifecta of easy opening. Getting in through the rear case is a snap.
    • Once you're inside, the battery can be peeled out and replaced with no tools.
    • A fused display assembly, glued into the front of the device, makes screen replacement a little difficult and costly.
29指南评论
why all the cheesy wording?
Justin Scarano - 回复
because he has some sense of fun/humor? Thankfully, geeks are no longer required to wear pocket protectors, or be humorless robots.
Philip Weiss -
Will there be a problem if sweat shorts the contact pins made for cradle?
Abhisek Jain - 回复
No, the contact sockets are deep enough to avoid any effect of sweat getting in.
rayramirez -
How/Why do we think the MPS14X 60X5V3 1410WeC is a Motorola Chip? Does Motorola still manufacture semiconductor products?
Joey M - 回复
The heart rate monitor is a bright green LED and a phototransistor.
rayramirez - 回复
What is the pinout of the contact pins?
Bruno Ausiello - 回复
My microphone don't work, where can I find a part for it?
abid - 回复
Where can I get replacement glass?
Chris Kalmbach - 回复
The sweat oxided the back contacts. How can I order a new back case?
franciscodreyfuss - 回复
I have the same issue.
oarivera1978 -
i think you have the scoring wrong for the samsung gear 2. i have just replaced the digitizer in mine and it couldn't have been simpler it definitely gets a 10 from me as the screen is not glued in. and i got my old one out easily in one piece.thanks for the instructions i probably wouldn't have attempted it without them.
Steve
the real spain - 回复
i lost the screws out of the wristband to attach to the metal plate at the end of strap...
richard - 回复
bama mom -
While assembling the gear 2 back, what should be used to make it water proof? Which glue can be used while assembling? I want to replace the charging connector PCB which I have ordered on eBay and waiting to be delivered.
Prakash Gadave - 回复
I need to replace mine too they wore out how did the repair go for you? Also can you please give me the link to order the parts
Brya -
please can i know which is the bluetooth chip i have a problem with it
ibrosman - 回复
My Gear S2 is 3 months old and the screws on the band also fell off while working out. This must be a
common flaw with the band. Can't locate replacement screws.
Any ideas out there ?
lewbb - 回复
I have my Samsung Gear S2 and the screws fell out of the band while working out .This may be a flaw with this band.
Any ideas on where to find replacement screws?
lewbb - 回复
my smart watch is not getting charge,charging pin in watch five copper pin in watch is got worn out....what i have to do
mr9611883724 - 回复
How do i replace the back copper contacts ? My gear will no longer charge because of 2 of the 5 missing. Please advise.
Alex
Alex Herrera - 回复
where can you get the contacts for the watch one of mine is worn and I have no connection to the cradle.
Butch McLeod - 回复
Nice write-up; thanks!
Philip Weiss - 回复
mi problema es con el pin de carga donde puedo conceguir esa parte
abatibatista464 - 回复
You think it'd be possible to replace the useless camera on the Gear 2 with an LED and make it a flashlight?
Jeremy Freer - 回复
My Gear 2 is different from the tear down example, probably a later model. There are no screws on the back. Anyone know how to get inside?
gettigo - 回复
When replacing the screen, what type of adhesive is used to secure it to the housing? The old gasket lost it’s tackiness and no longer holds. Is that a replacement part as well or should I turn to super glue?
Pete - 回复
How can I replace the screen?
Kam - 回复
I have this same issue here.
Giovanni Cardenas - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 102,719
