简介
转到步骤 1What would you do for a OnePlus 2? We're a little shy, so we asked OnePlus if we could skip the dance party and flashmob contests, and they happily sent us a unit to rip apart. Kudos for their bravery.
Self-styled as the "2016 flagship killer," the OnePlus 2 steps into the Android phone market with circus-clown-sized shoes to fill. After the OnePlus 1's lackluster repairability score last year, we're hopeful that the new model brings some refinements and improvements for repair-minded folk like ourselves.
Follow along as we disassemble OnePlus' latest offering and see if they'll "never settle" for a 5/10 in repairability again.
Here are OnePlus 2 different ways to keep up with the latest teardown news: follow us on Facebook, Instagram, or Twitter!
视频概述
The OnePlus 2 will need a bit of brawn to beat the big boys. Let's check its specs:
5.5-inch IPS display (1920x1080, 401 PPI)
13 MP main camera, 5 MP selfie cam; up to 4K video; 720p slow-mo at 120fps
64-bit Qualcomm Snapdragon 810 processor with 1.8 GHz Octa-core CPU and Adreno 430 GPU
3 or 4 GB LPDDR4 RAM
16 or 64 GB eMMC v5.0 storage capacity
802.11a/n/ac Wi-Fi, Bluetooth 4.1, GPS/GLONASS, Digital Compass—and USB-C connectivity (a pretty snazzy cherry to top off these features)
Meet the new "alert slider." OnePlus has developed a "volume" control for your notifications, throttling to various levels of priority with a single switch.
On the back of the phone, we find the highly touted six-element, 13 MP, f/2.0 rear-facing camera, flash, and laser autofocus blaster.
Is that a USB-C port we USB-see?
One of the first mass-market smartphones with a USB-C port, the OnePlus 2 gets the benefit of a reversible connector—though it seemingly lacks the faster charging and data transfer abilities we'd hope for.
the port is only Type-C, but it's still 2.0 underneath, so it's not any faster than the other phones
Good catch! We've updated the text.
Like another recent flagship Android phone, the OnePlus 2 lacks external screws.
Thankfully, OnePlus has also foregone the use of adhesive for the rear cover, instead opting for plastic clips.
We got our hopes up, but prying the case up revealed a solid midframe, no battery in sight.
And at least we have access to the dual-slotted Nano SIM tray, no SIM eject tool needed.
With the rear cover removed, we set to work on a vast legion of screws. It's miles better than glue, but there are just so many... Fortunately, our Pro Tech Screwdriver Set is on hand to face down this gaggle of Phillips fasteners.
The OnePlus 2 hits back as we find even more screws hidden away beneath rubber covers.
We also find a single screw wearing a tamper-evident seal—one that we're pretty sure OnePlus expected would be broken...
Turns out that well-secured midframe is a thin plastic cover—now (minus 18 screws) easily removed.
A peek inside reveals the signature red battery and a bit of the motherboard.
There's not much left in the midframe cover—just a loudspeaker, and cover lenses for the camera and LED flash. We'll move on to greener and more tempting pastures...
Looking for a OnePlus 2 Camera Lens Middle Frame as well!
please let met know if you got mid frame lens
chaks -
I'm looking for one too! Have you guys found one yet?
I think i could replace my OPO's battery with OP2, what suggestions? Are the dimensions same? I'd like to add those 200mAh.
"Battery is not removable," you say. Sounds like a challenge to us.
The not-removable battery makes a pretty red target for our grabby teardown hands.
At 3.8 V and 3,300 mAh, this battery also provides a slight improvement from the One's 3,100 mAh lithium polymer cell.
Smartphones today are without a doubt the go-to photography tool (camera!) of choice. That makes the shooters in these smart devices a cardinal comparator. Here's what OnePlus brings against the competition:
13 MP, f/2.0 rear-facing camera with Optical Image Stabilization and Dual-LED flash.
5 MP front-facing selfie camera.
According to our research, the main camera sports an Omnivision OV13860 PureCel-S image sensor while the selfie camera uses a 5 MP OmniVision OV5648.
That rear-facing camera features 1.3 µm light-collecting pixels—the biggest ever in a 13 MP smartphone camera.
Taking a closer look with our X-ray vision, we can clearly make out the electromechanical actuators that move the lens, providing that optical image stabilization.
One last component makes up the OnePlus 2's fancy photographer: The infrared laser rangefinder.
This component is made up of two parts: an IR LED and matched receiver.
The IR LED probably projects a cone of IR light on the subject, which bounces to the receiver. This lets the camera estimate the distance to the subject, and snap the focus to match.
在这个步骤中使用的工具:Spudger$2.99
Our always-trusty spudger shows up to detach the handful of cables still keeping the motherboard in place.
A few of the many midframe screws served to secure the motherboard—but having dispatched those previously, we're faced with just one more.
Screw removed, alert slider up, and—with a bit of prying—the motherboard is out.
Samsung K3RG2G2 LPDDR4 dual-channel RAM, with the Qualcomm Snapdragon 810 layered beneath
Qualcomm PM899
Qualcomm WCD9330 audio codec
Qualcomm PMI8994 Power Management IC
RF Micro Devices RF7389EU multi-band power amplifier
Skyworks 77814-11 power amplifier module for LTE
Qualcomm WTR3905 RF transceiver for dual SIM support
Qualcomm QFE1100 envelope tracking IC
what is the name of this part?
Hi, how is this part called? need to buy it new
And on the reverse...
Qualcomm QCA6174 802.11ac Wi-Fi 2x2 MIMO combo SoC
Samsung KLMCG8GEND-B031 eMMC 64 GB NAND flash memory
NXP TFA9890 audio amplifier
Is the SIM card slot mechanism soldered to the board? If no, how is it attached?
The USB-C port cable is pretty barebones—just a couple of (mysterious) spring contacts, which is good news for repair.
It's a little more fiddly than last year's One, but certainly not the Apple standard charging port mess.
USB-C is a pretty new addition to the smartphone world, so naturally we took a peek inside.
Looking at several of the high-resolution photos, my best guess about the two mysterious spring contacts is that they sense when the back is off the device.
I figured possible dock support with a cover change
its for Hydrogen, it reads which SwapStyle you have and applies a theme to the OS. pretty cool feature, but useless for the USA =[
Cooler? How? Great, it may not get as loose as microUSB (at least not as fast), but it can't even charge at 2A. Lightning can, without "oh does it support fast charging 2.0 or USB 3.1 or blah blah blah", and it's still bigger than Lightning. Seems like a personal opinion/preference thing. Not to mention that it's 3 years late, and is available in, what, 2 phones at this point? Lightning has worked well for a full 3 years and even when it was first released, doesn't get loose. That remains to be seen with USB-C.
I think what's meant by the statement is that the OnePlus Two is compliant with standards, rather than making their own for seemingly no reason or need.
Under the charging port cable, we strike daughterboard. Eureka!
The little foam foundation is the speaker box for that loudspeaker we spied in the midframe.
The daughterboard also houses a familiar classic: a coin-style vibration motor. Unfortunately, you'll need a soldering iron to replace it.
On the backside we find yet more spring contacts, a microphone, and the soft button LEDs. Like the motherboard, this daughter is a busy board.
What does the One Plus Two use for cooling the SoC? I didn't see any copper heatpipes.
在这个步骤中使用的工具:iOpener$12.99
It was bound to happen sooner or later—out comes the iOpener to beat down the adhesive that secures the display to the midframe of the device.
After a quick spot of heat under the iOpener, the display of the OnePlus 2 is easily freed using a couple opening picks.
We finally get a good look at the backside of the 5.5-inch display assembly next to the now-empty shell of the midframe.
On the rear of the display we find the Synaptics S3320A touch controller that governs the touchscreen.
We also get a look at what turns out to be a soft home button which sits awkwardly below the very delicate side button cables. This is sure to make replacing the home button more of a hassle than it should be.
Keeping pace with Apple and Samsung, the OnePlus 2 features a fingerprint sensor. The FPC1150 touch fingerprint sensor by Fingerprint Cards AB can recognize up to five fingerprints and will read them in any orientation.
Is it possible to remove and replace the fingerprint-sensor? Thanks in advance!
Yes it is possible. But its very important to reassamble the kaptontape. If you forget the kapton tape you have a grounding problem and youre touchscreen wont work properly
How easy or not is to disassemble button strip under the screen? Thanks
OnePlus 2 Repairability Score: 7 out of 10 (10 is easiest to repair).
A single (non-proprietary) screw head decreases cost of tools for repairs.
Many components are modular and can be replaced independently.
USB-C port is on a relatively simple flex cable, not an assembly—it should be an inexpensive replacement.
Despite the warning, the battery is fairly easily removed—but still requires disassembly.
The LCD and digitizer glass are fused together and must be replaced as a single part; heat is required to remove it from the midframe.
33条评论
What type of gyro/accel is present? What are the ICs on the camera circuit board - are these OIS gyros?
Is there any NFC hardware present on the phone?
suneth5000 - 回复
Nope! OnePlus claims that there are currently not enough NFC applications to justify including NFC hardware in the OP2.
Does anyone knows if the Oneplus 2 has the same problem as the 1 has. Is the digitizer also broken even there is even 1 crack in the lcd?
no my one plus two had a broken screen where the glass was cracked. But the digitizer was fine.
Sean Kim -
Would it be possible to fix in a wireless charging adapter from eBay to the USB connector cable and if yes can you provide some instructions please. Is it possible to attach an NFC sensor via similar connection via USB cable attachment inside the back near the connector attachment once the screw's are removed please. Any walk through guide for such a mod and parts needed would be useful.
The spring contacts in the back are for swap covers. My swap covers have contacts on them while the original cover does not.
For the teardown guys - could you point out the WIFI and MIMO antenna present on the oneplus two? And if there is only one wifi antenna or two wifi antennas present for a 1x1:1 configuration or 2x2:2 configuration. Currently experiencing wifi speeds evident of a single antenna even though the chip present is capable of dual antenna setups.
yes please tell us were the MIMO antenna is thank you
bbmllr4 -
I downloaded the picture of Step 12, the picture clearly shows it is QCA6164 (with 1T1R) rather than 6174.
However, I run software tool lspci, pci vendir-id / device-id is : 168c:003e which means qca6174. qca6164's device-id is 0041 (not 003e). This contradicts with the picture.
My oneplus 2 is A2001. Wikipedia says there is A2003 and A2005 too. I am not sure if this picture is taken from A2005 or Oneplus uses different chips in their different shipment.
@hungry4cheese Would you please tell what is the model number, is it A2005?
please help!!!!
wifi and blutooth have stopped working.
i cant even press on the botton because its grey. and when i press it- it does nothing.
what can i do?
אסף פנסו -
Wow, very excited, the tear down is very good, could tear done the Bluboo Xtouch? I read from some website the comparison between Oneplus two and Xtouch, seems that the Bluboo Xtouch is very good
Would anyone know where I could purchase a replacement power/volume button cable any advice would be appreciated.
Can you replace the speaker?? I broke mine..
What kind of adhesive do you need for the screen, I need to replace mine and don't want it to end up looking ghetto.
Hi i am looking for one plus 2 side button (internal)
Hi i am looking for one plus 2 side button (internal).
My phone no longer communicates with any computer via fastboot mode / via multiple drive installs. Is there a way to kill power to phone and and force a hardware reset so my device can be recognized / communicate again with the processor / software ...... Would unplugging the battery accomplish this?
Much pleasure!!
You can send to Brazil the USB-C port (g4QWMTIoSe5YrLWR)?
My device damaged the part and can not connect to the wifi.
If possible, what would be the price and shipping time to Brazil?
Since I thank attention !!
For contact: gd_alvarenga@hotmail.com
My fingerprint sensor stopped working after a little water damage. Any way I can repair it myself? If not would it be a expensive replacement?
Can anyone help me?
I've just replaced the screen and mid case(it came as one part/attached)
Every thing seems to have gone fine, except my Wi-Fi and Bluetooth will not switch on now.
The icons in the notification bar are grey and do not change when pressed.
Any advice is appreciated.
Please can u tell me tat what I should to Whn the screen of my one plus 2 is slightly raised oneside
prathi1688 - 回复
hi,
where the wifi antena is located
Hi, my mute button is broken from the motherboard, does anyone know how to fix that? I broke it by dissembling wrongly my One plus 2
Jugeswar majhi
