简介
使用本指南对iPhone 5s 音量键和静音键进行更换。
首先需要移除电池。理论上移除胶条是没有什么损伤的,但会使电池没有黏性。当重组的时候,可以使用双面胶。这样电池就会粘在后盖上,并且不会晃动。
你所需要的
握紧iSclack的把手,打开它的吸盘口。
把你iPhone的底部放置在两个吸盘之间,紧紧靠住塑料的深度计。
上面吸盘应该刚好在home键的上方位置。
使用iSclack把手把钳口合上。把吸盘放到手机中间,并且把吸盘牢牢地按到iPhone屏幕上和机身底部。
拿紧你的iPhone,然后合拢iSclack的把手,这样屏幕就和机身分离开来。
iSclack是专门设计用来打开你的iPhone的,它能够很好的保证在分离屏幕和机身时不扯断Home 键排线。
跳过下面三步,直接到第九步。
一只手固定好iPhone机身,另一只手轻轻地把机身从前面板底端的home键上分离。
当你左手使用吸盘拉动的时候,右手用塑料撬棒在后机壳边缘处,轻轻地撬动,使屏幕和机身分离。
稍微打开屏幕,可以看到盖住home键电线的挡板铁片就可以了。
只有手机原装的Home键组件才能使用Touch ID功能。如果你扯断这根电线,装上新的home键只能恢复home键功能,而将失去Touch ID功能。
使用手机撬棒推动松下铁片,再用镊子取下来。
一旦连接器被撬开了后,把home键底端从机身上拉起,把手机顶端当做一个转动支点。
把显示屏立起来,保持跟机身成90度角。在你维修手机的过程中一直保持这个状态。
用橡皮筋把显示屏如图三所示固定住。这会避免在维修过程中显示屏电缆的损坏。
如果电池仍然粘在后壳上,请准备一个 iOpener 或使用吹风机直接加热电池后面的iPhone后盖。
在电池顶部与后盖之间穿入一条牙线或者弦,首尾放在一起,然后用折叠的布料包起来,均匀地拉动。
请倒序重组你的设备。
请倒序重组你的设备。
55等其他人完成本指南。
由衷感谢以下译者:
85%
Warrior E正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
My phone was shattered and i did a total replacement of the rear case and the screen. All went well except... the volume controls do not work. The silence button above it does, but the +- dont. They feel wrong when pressed. They don't make the clicking sound. Anyone a suggestion of what went wrong?
I had to replace the power flex cable, which means taking almost everything out. Scary! When I restarted, my power button and flash were fixed but my volume was the same as yours and my home button didn't work. :( That Touch ID cable and cover are from h#$l! Anyway, I went back in and everything is working now. Instead of doing them like in the photos and videos, I attached the silence button first and then the volume buttons. So when you put in the middle screw that holds them both in, the screw goes through volume first and then silence.
Oh ya, ifixit is a great resource. Thanks!
I noticed one thing during my replacement that may affect others doing this repair. Upon reaching step 30 I noticed that my volume button bracket appeared to be bent slightly near the lower screw (the one toward the bottom of the case). Ultimately I had to bend the bracket to make the volume button work correctly. When I reassembled the bracket with the new buttons before bending it the - button would not come back fully to its normal position. After careful bending with a pair of needle nose pliers and the button worked correctly.
It is CRITICAL that you test your volume buttons and the ringer switch before you reassemble your phone!
