跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Max Screen Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Pro Max Screen Removal, Create a gap with a suction handle: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    iOpener
    $14.99
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
  2. iPhone 16 Pro Max Screen Removal: 步骤 2 中的图像 1,3 iPhone 16 Pro Max Screen Removal: 步骤 2 中的图像 2,3 iPhone 16 Pro Max Screen Removal: 步骤 2 中的图像 3,3
    • Apply a suction handle to the bottom edge of the screen.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • If you can't create a gap, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
  3. iPhone 16 Pro Max Screen Removal, Screen information: 步骤 3 中的图像 1,1
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
    • Multiple spring contacts around the perimeter of the iPhone
  4. iPhone 16 Pro Max Screen Removal, Slice the bottom edge adhesive: 步骤 4 中的图像 1,2 iPhone 16 Pro Max Screen Removal, Slice the bottom edge adhesive: 步骤 4 中的图像 2,2
    • Slide the opening pick along the bottom edge to release the adhesive.
    • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
    • If the adhesive feels difficult to slice, reheat the edge for a minute.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
  5. iPhone 16 Pro Max Screen Removal, Heat the left edge: 步骤 5 中的图像 1,1
    • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
  6. iPhone 16 Pro Max Screen Removal, Separate the left adhesive: 步骤 6 中的图像 1,2 iPhone 16 Pro Max Screen Removal, Separate the left adhesive: 步骤 6 中的图像 2,2
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
    • Insert a second opening pick in the bottom-left corner, close to the existing pick.
    • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
  7. iPhone 16 Pro Max Screen Removal, Separate the remaining adhesives: 步骤 7 中的图像 1,3 iPhone 16 Pro Max Screen Removal, Separate the remaining adhesives: 步骤 7 中的图像 2,3 iPhone 16 Pro Max Screen Removal, Separate the remaining adhesives: 步骤 7 中的图像 3,3
    • Repeat the heating and slicing procedure along the remaining screen edges.
  8. iPhone 16 Pro Max Screen Removal, Swing open the screen: 步骤 8 中的图像 1,3 iPhone 16 Pro Max Screen Removal, Swing open the screen: 步骤 8 中的图像 2,3 iPhone 16 Pro Max Screen Removal, Swing open the screen: 步骤 8 中的图像 3,3
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
    • Carefully lift the screen upwards until the clips along the long edges clear the frame.
    • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
  9. iPhone 16 Pro Max Screen Removal, Remove the connector covers: 步骤 9 中的图像 1,1
    • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
  10. iPhone 16 Pro Max Screen Removal: 步骤 10 中的图像 1,3 iPhone 16 Pro Max Screen Removal: 步骤 10 中的图像 2,3 iPhone 16 Pro Max Screen Removal: 步骤 10 中的图像 3,3
    • Use tweezers to grasp the front sensor connector cover near the screw hole.
    • Lift and remove the cover.
    • Repeat the procedure to remove the display connector cover.
  11. iPhone 16 Pro Max Screen Removal, Disconnect the screen: 步骤 11 中的图像 1,3 iPhone 16 Pro Max Screen Removal, Disconnect the screen: 步骤 11 中的图像 2,3 iPhone 16 Pro Max Screen Removal, Disconnect the screen: 步骤 11 中的图像 3,3
    • Use the tip of a spudger to pry up and disconnect the display press connector.
    • Repeat for the front sensor press connector.
  12. iPhone 16 Pro Max Screen Removal, Remove the screen: 步骤 12 中的图像 1,1
    • Lift the screen and remove it.
终点
Arthur Shi
于01/03/18注册
323,210 声望
创作了793篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,173篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 37
总计 254
