简介
Use this guide to remove and replace the loudspeaker in your iPhone 14 Pro.
This guide was created using the A2890 (international) model. If you're fixing a different iPhone 14 Pro model, there may be some visual discrepancies, but the procedure should be the same.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
你所需要的
Power off your iPhone before beginning disassembly.
Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
在这个步骤中使用的工具:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Apply a suction handle to the bottom edge of the screen, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
Insert an opening pick into the gap under the screen's plastic bezel.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
Continue sliding up the right edge of the iPhone until you reach the top right corner.
Leave the pick in the top right corner before continuing.
Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
Leave the pick in the top left corner before continuing.
Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
Insert a second opening pick in the bottom left corner of the iPhone.
Twist both picks simultaneously until the left edge clips release.
Remove your suction handle from the screen.
Rotate your iPhone so the right edge faces you.
Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
Lean the screen against something to keep it propped up while you're working on the phone.
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Use a Y000 screwdriver to remove the eight screws securing the battery connector cover:
Five 1.3 mm-long screws
Two 1.6 mm-long screw
One 1.9 mm-long screw
Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use the pointed end of a spudger to disconnect the first display cable by prying the connector straight up from its socket.
Use a Phillips driver to remove the four 1.5 mm-long screws securing the loudspeaker.
Use the flat end of a spudger to pry up and loosen the loudspeaker from the bottom-right corner of the phone.
2等其他人完成本指南。
2条评论
Be sure to purchase the correct size speaker. What You Need section lists iPhone 14 Pro Max, but its bigger than the non-max version.
Hi Edgar, thanks for the note! I've corrected the erroneous part in the "What You Need" section.
