跳转到主内容
iPhone 14 Pro Lidar Sensor Replacement
你所需要的
  1. iPhone 14 Pro Lidar Sensor Replacement, Remove the pentalobe screws: 步骤 1 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Remove the pentalobe screws: 步骤 1 中的图像 2,2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Pro Lidar Sensor Replacement, Heat the bottom edge of the iPhone: 步骤 2 中的图像 1,1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the screen, making it easier to open.
    • Apply a heated iOpener to the bottom edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
  3. iPhone 14 Pro Lidar Sensor Replacement, Anti-Clamp instructions: 步骤 3 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Anti-Clamp instructions: 步骤 3 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Anti-Clamp instructions: 步骤 3 中的图像 3,3
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPhone 14 Pro Lidar Sensor Replacement: 步骤 4 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement: 步骤 4 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement: 步骤 4 中的图像 3,3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  5. iPhone 14 Pro Lidar Sensor Replacement, Insert an opening pick: 步骤 5 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Insert an opening pick: 步骤 5 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Insert an opening pick: 步骤 5 中的图像 3,3
    • Apply a suction handle to the bottom edge of the screen, while avoiding the very edge of the glass.
    • Pull up on the suction handle with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  6. iPhone 14 Pro Lidar Sensor Replacement, Heat and separate the screen adhesive: 步骤 6 中的图像 1,1
    • Apply a heated iOpener to the left edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  7. iPhone 14 Pro Lidar Sensor Replacement, Slice the left edge adhesive: 步骤 7 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Slice the left edge adhesive: 步骤 7 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Slice the left edge adhesive: 步骤 7 中的图像 3,3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the screen in place.
    • Don't insert the pick more than 3 mm inside your phone, or you may damage the display cables.
  8. iPhone 14 Pro Lidar Sensor Replacement, Heat and separate the screen adhesive: 步骤 8 中的图像 1,1
    • Apply a heated iOpener to the right edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  9. iPhone 14 Pro Lidar Sensor Replacement, Slice the right edge adhesive: 步骤 9 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Slice the right edge adhesive: 步骤 9 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Slice the right edge adhesive: 步骤 9 中的图像 3,3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert the opening pick more than 3 mm into the iPhone, or you may cause damage to internal components.
  10. iPhone 14 Pro Lidar Sensor Replacement, Heat the top edge of the iPhone: 步骤 10 中的图像 1,1
    • Apply a heated iOpener to the top edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  11. iPhone 14 Pro Lidar Sensor Replacement, Slice the top edge adhesive: 步骤 11 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Slice the top edge adhesive: 步骤 11 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Slice the top edge adhesive: 步骤 11 中的图像 3,3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and half way across the top edge stopping right before the earpiece speaker cut-out.
    • Don't insert the pick more than 2 mm or you may damage the front panel sensor array.
  12. iPhone 14 Pro Lidar Sensor Replacement: 步骤 12 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement: 步骤 12 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement: 步骤 12 中的图像 3,3
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and half way across the top edge stopping right before the earpiece speaker cut-out.
    • Again, don't insert the pick more than 3 mm or you may damage the front panel sensor array.
    • Don't try to fully separate the screen yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  13. iPhone 14 Pro Lidar Sensor Replacement, Open the iPhone: 步骤 13 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Open the iPhone: 步骤 13 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Open the iPhone: 步骤 13 中的图像 3,3
    • Remove your suction handle from the screen.
    • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
    • Lean the screen against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
    • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
    • Use a Y000 screwdriver to remove the eight screws securing the battery connector cover:
    • Six 1.3 mm-long screws
    • One 1.6 mm-long screw
    • One 1.9 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
  14. iPhone 14 Pro Lidar Sensor Replacement, Remove the battery connector cover: 步骤 15 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Remove the battery connector cover: 步骤 15 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Remove the battery connector cover: 步骤 15 中的图像 3,3
    • Grasp the connector cover with a pair of tweezers and slide it downwards to clear the flex cables.
    • Remove the connector cover.
  15. iPhone 14 Pro Lidar Sensor Replacement, Disconnect the battery: 步骤 16 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Disconnect the battery: 步骤 16 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Disconnect the battery: 步骤 16 中的图像 3,3
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  16. iPhone 14 Pro Lidar Sensor Replacement, Disconnect the display cable: 步骤 17 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Disconnect the display cable: 步骤 17 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the first display cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. iPhone 14 Pro Lidar Sensor Replacement: 步骤 18 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement: 步骤 18 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the second display cable by prying the connector straight up from its socket.
  18. iPhone 14 Pro Lidar Sensor Replacement, Remove the screen: 步骤 19 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Remove the screen: 步骤 19 中的图像 2,2
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the screen adhesives.
  19. iPhone 14 Pro Lidar Sensor Replacement, Unfasten the rear-facing camera assembly cover screws: 步骤 20 中的图像 1,1
    • Use a Y000 driver to remove the five screws securing the rear-facing camera assembly cover:
    • Four 1.5 mm-long Y000 screws
    • One 1.3 mm-long Y000 screw
    • Use a Phillips screwdriver to remove one 1.7 mm-long screw.
  20. iPhone 14 Pro Lidar Sensor Replacement, Remove the rear-facing camera assembly cover: 步骤 21 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Remove the rear-facing camera assembly cover: 步骤 21 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Remove the rear-facing camera assembly cover: 步骤 21 中的图像 3,3
    • There's a small metal edge in the top right corner of the rear-facing camera assembly cover that is secured by the phone frame.
    • Grab the rear-facing camera assembly cover with a pair of tweezers.
    • Move the rear-facing camera assembly cover toward the volume buttons to free its small metal edge from the frame.
    • Remove the rear-facing camera assembly cover.
    • During reassembly, make sure to align the rear-facing camera assembly cover correctly and push the small metal edge back into its recess in the frame.
  21. iPhone 14 Pro Lidar Sensor Replacement, Disconnect the ultra wide and telephoto camera cable: 步骤 22 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Disconnect the ultra wide and telephoto camera cable: 步骤 22 中的图像 2,2
    • Use a spudger to disconnect the ultra wide and telephoto lens cable by prying the connector straight up from its socket.
  22. iPhone 14 Pro Lidar Sensor Replacement, Disconnect the wide lens camera cable: 步骤 23 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Disconnect the wide lens camera cable: 步骤 23 中的图像 2,2
    • Use a spudger to disconnect the wide lens cable by prying the connector straight up from its socket.
  23. iPhone 14 Pro Lidar Sensor Replacement, Pry up the rear-facing camera assembly: 步骤 24 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Pry up the rear-facing camera assembly: 步骤 24 中的图像 2,2
    • Insert the pointed end of a spudger underneath the bottom edge of the rear-facing camera assembly.
    • Pry up with the spudger to loosen the rear-facing camera assembly.
  24. iPhone 14 Pro Lidar Sensor Replacement, Remove the rear-facing camera assembly: 步骤 25 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Remove the rear-facing camera assembly: 步骤 25 中的图像 2,2
    • Use a pair of tweezers or your fingers to remove the rear-facing camera assembly.
  25. iPhone 14 Pro Lidar Sensor Replacement, Unfasten the lidar sensor cover screw: 步骤 26 中的图像 1,1
    • Use a standoff screwdriver to remove the 2.8 mm-long standoff screw securing the lidar sensor cover.
  26. iPhone 14 Pro Lidar Sensor Replacement, Remove the lidar sensor cover: 步骤 27 中的图像 1,3 iPhone 14 Pro Lidar Sensor Replacement, Remove the lidar sensor cover: 步骤 27 中的图像 2,3 iPhone 14 Pro Lidar Sensor Replacement, Remove the lidar sensor cover: 步骤 27 中的图像 3,3
    • Use a pair of tweezers to remove the lidar sensor cover.
  27. iPhone 14 Pro Lidar Sensor Replacement, Disconnect the lidar sensor: 步骤 28 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Disconnect the lidar sensor: 步骤 28 中的图像 2,2
    • Use a spudger to disconnect the lidar sensor cable by prying the connector straight up from its socket.
  28. iPhone 14 Pro Lidar Sensor Replacement, Pry up the lidar sensor: 步骤 29 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Pry up the lidar sensor: 步骤 29 中的图像 2,2
    • Insert the flat end of a spudger underneath the top edge of the lidar sensor.
    • Pry up with the spudger to loosen the lidar sensor.
  29. iPhone 14 Pro Lidar Sensor Replacement, Remove the lidar sensor: 步骤 30 中的图像 1,2 iPhone 14 Pro Lidar Sensor Replacement, Remove the lidar sensor: 步骤 30 中的图像 2,2
    • Use a pair of tweezers to remove the lidar sensor.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
团队
iFixit iFixit 的会员
Community
138 名成员
创作了16,927篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 61
过去 30 天: 230
总计 1,094
