跳转到主内容
iPhone 14 Battery Replacement
你所需要的
  1. iPhone 14 Battery Replacement, Remove the pentalobe screws: 步骤 1 中的图像 1,2 iPhone 14 Battery Replacement, Remove the pentalobe screws: 步骤 1 中的图像 2,2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Battery Replacement, Heat the lower edge of the iPhone: 步骤 2 中的图像 1,1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the rear glass, making it easier to open.
    • Apply a heated iOpener to the bottom edge of the rear glass to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
  3. iPhone 14 Battery Replacement, Anti-Clamp instructions: 步骤 3 中的图像 1,3 iPhone 14 Battery Replacement, Anti-Clamp instructions: 步骤 3 中的图像 2,3 iPhone 14 Battery Replacement, Anti-Clamp instructions: 步骤 3 中的图像 3,3
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  4. iPhone 14 Battery Replacement: 步骤 4 中的图像 1,3 iPhone 14 Battery Replacement: 步骤 4 中的图像 2,3 iPhone 14 Battery Replacement: 步骤 4 中的图像 3,3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the rear glass when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  5. iPhone 14 Battery Replacement, Insert an opening pick: 步骤 5 中的图像 1,3 iPhone 14 Battery Replacement, Insert an opening pick: 步骤 5 中的图像 2,3 iPhone 14 Battery Replacement, Insert an opening pick: 步骤 5 中的图像 3,3
    • Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
    • Insert an opening pick into the gap.
    • The adhesive holding the rear glass in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the rear glass up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  6. iPhone 14 Battery Replacement, Heat and separate the rear glass adhesive: 步骤 6 中的图像 1,1
    • Apply a heated iOpener to the left edge of the rear glass to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  7. iPhone 14 Battery Replacement, Slice the left edge adhesive: 步骤 7 中的图像 1,3 iPhone 14 Battery Replacement, Slice the left edge adhesive: 步骤 7 中的图像 2,3 iPhone 14 Battery Replacement, Slice the left edge adhesive: 步骤 7 中的图像 3,3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
    • Don't insert the pick more than 3 mm inside your phone, or you may damage components.
  8. iPhone 14 Battery Replacement, Heat and separate the rear glass adhesive: 步骤 8 中的图像 1,1
    • Apply a heated iOpener to the right edge of the rear glass to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  9. iPhone 14 Battery Replacement, Slice the right edge adhesive: 步骤 9 中的图像 1,3 iPhone 14 Battery Replacement, Slice the right edge adhesive: 步骤 9 中的图像 2,3 iPhone 14 Battery Replacement, Slice the right edge adhesive: 步骤 9 中的图像 3,3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your opening pick more than 3 mm into the iPhone to prevent damaging the charging coil cable.
  10. iPhone 14 Battery Replacement, Heat the top edge of the iPhone: 步骤 10 中的图像 1,1
    • Apply a heated iOpener to the top edge of the rear glass to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  11. iPhone 14 Battery Replacement, Slice the top edge adhesive: 步骤 11 中的图像 1,3 iPhone 14 Battery Replacement, Slice the top edge adhesive: 步骤 11 中的图像 2,3 iPhone 14 Battery Replacement, Slice the top edge adhesive: 步骤 11 中的图像 3,3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
  12. iPhone 14 Battery Replacement: 步骤 12 中的图像 1,3 iPhone 14 Battery Replacement: 步骤 12 中的图像 2,3 iPhone 14 Battery Replacement: 步骤 12 中的图像 3,3
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
    • Don't insert the pick more than 3 mm or you may damage or smear the camera array.
    • Don't try to fully separate the rear glass yet, as a fragile ribbon cable still connects it to the iPhone's logic board.
  13. iPhone 14 Battery Replacement, Open the iPhone: 步骤 13 中的图像 1,3 iPhone 14 Battery Replacement, Open the iPhone: 步骤 13 中的图像 2,3 iPhone 14 Battery Replacement, Open the iPhone: 步骤 13 中的图像 3,3
    • Remove your suction handle from the rear glass.
    • Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
    • Be careful not to strain the short charging coil flex cable.
    • Lean the rear glass against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
    • During reassembly, lay the rear glass in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the rear glass and make sure they aren't bent.
    • Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  14. iPhone 14 Battery Replacement, Remove the battery connector cover: 步骤 15 中的图像 1,3 iPhone 14 Battery Replacement, Remove the battery connector cover: 步骤 15 中的图像 2,3 iPhone 14 Battery Replacement, Remove the battery connector cover: 步骤 15 中的图像 3,3
    • Grasp the battery connector cover with a pair of tweezers and slide it upwards (towards the A15 print) to unlatch the top hook.
    • Remove the battery connector cover.
  15. iPhone 14 Battery Replacement, Disconnect the battery: 步骤 16 中的图像 1,2 iPhone 14 Battery Replacement, Disconnect the battery: 步骤 16 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  16. iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: 步骤 17 中的图像 1,2 iPhone 14 Battery Replacement, Unfasten the charging coil connector cover screw: 步骤 17 中的图像 2,2
    • Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
  17. iPhone 14 Battery Replacement, Remove the charging coil connector bracket: 步骤 18 中的图像 1,2 iPhone 14 Battery Replacement, Remove the charging coil connector bracket: 步骤 18 中的图像 2,2
    • Use a pair of tweezers to remove the charging coil connector cover.
  18. iPhone 14 Battery Replacement, Disconnect the charging coil: 步骤 19 中的图像 1,2 iPhone 14 Battery Replacement, Disconnect the charging coil: 步骤 19 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
  19. iPhone 14 Battery Replacement, Remove the rear glass assembly: 步骤 20 中的图像 1,2 iPhone 14 Battery Replacement, Remove the rear glass assembly: 步骤 20 中的图像 2,2
    • Remove the rear glass assembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the rear glass adhesives.
  20. iPhone 14 Battery Replacement, Locate the adhesive pull-tabs: 步骤 21 中的图像 1,1
    • Two stretch adhesive strips secure the battery to the case. They're both accessed from the top edge of the battery.
    • Each adhesive strip has a black pull-tab at the end, which is lightly adhered to the edge of the battery.
    • In the following steps, you'll pull each tab to slowly stretch out the adhesive underneath the battery. These "command-strip" style adhesives lose their stick when stretched, so you can remove the battery with ease.
    • If the strips break, don't panic! They don't always work as intended. Keep reading for tips on removing broken strips.
  21. iPhone 14 Battery Replacement, Remove the stretch-release adhesive: 步骤 22 中的图像 1,3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: 步骤 22 中的图像 2,3 iPhone 14 Battery Replacement, Remove the stretch-release adhesive: 步骤 22 中的图像 3,3
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    • Use a pair of blunt-nosed tweezers to peel up the two battery adhesive pull-tabs along the top edge of the battery.
  22. iPhone 14 Battery Replacement: 步骤 23 中的图像 1,3 iPhone 14 Battery Replacement: 步骤 23 中的图像 2,3 iPhone 14 Battery Replacement: 步骤 23 中的图像 3,3
    • Grab the first pull-tab with your fingers or wrap it around a spudger and slowly pull it away from the battery, toward the top of the iPhone.
    • Pull out hard enough to maintain tension on the strip, but don't force it. Give it plenty of time to stretch and un-stick from under the battery.
    • Don't press down on the battery but hold the iPhone firmly by its sides.
    • Keep the strip flat and unwrinkled. Try to pull evenly on the whole strip, rather than pulling mainly in the middle or on one side.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • If any of the adhesive strips break off underneath the battery and can't be retrieved, try to remove the other strip, and then proceed as instructed below.
  23. iPhone 14 Battery Replacement: 步骤 24 中的图像 1,3 iPhone 14 Battery Replacement: 步骤 24 中的图像 2,3 iPhone 14 Battery Replacement: 步骤 24 中的图像 3,3
    • Grab the second pull-tab with your fingers or the center of a spudger and pull it away from the battery, toward the top of the iPhone.
    • Follow the same procedure as with the previous strip: don't press down on the battery, keep the strip flat and unwrinkled, and pull at a low angle.
    • If the adhesive breaks off underneath the battery and can't be retrieved, continue with the next step.
  24. iPhone 14 Battery Replacement, How to remove a stuck battery: 步骤 25 中的图像 1,3 iPhone 14 Battery Replacement, How to remove a stuck battery: 步骤 25 中的图像 2,3 iPhone 14 Battery Replacement, How to remove a stuck battery: 步骤 25 中的图像 3,3
    • If you're still having trouble removing the battery, apply a few drops of high concentration (90% or higher) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
    • Wait about one minute for the alcohol solution to weaken the adhesive.
    • Use an opening pick or the flat end of a spudger to gently lift the battery.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  25. iPhone 14 Battery Replacement, Remove the battery: 步骤 26 中的图像 1,2 iPhone 14 Battery Replacement, Remove the battery: 步骤 26 中的图像 2,2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off before installing your new battery.
    • If your new battery didn't come with adhesive preinstalled, refer to this guide for help replacing the adhesive strips.
    • Perform a force restart after reassembly. This can prevent several issues and simplify troubleshooting.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
107,302 声望
创作了185篇指南
团队
iFixit iFixit 的会员
Community
138 名成员
创作了16,962篇指南
一条评论
Salut.
Je veux savoir plus de cette formation dépannage.
cfas fix - 回复
添加评论
浏览统计数据:
过去 24 小时: 53
过去 7 天: 507
过去 30 天: 1,941
总计 10,612
