跳转到主内容
iPhone 13 Pro Max Screen Replacement
你所需要的
  1. iPhone 13 Pro Max Screen Replacement, Remove the pentalobe screws: 步骤 1 中的图像 1,1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 13 Pro Max Screen Replacement, Mark your opening picks: 步骤 2 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Mark your opening picks: 步骤 2 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Mark your opening picks: 步骤 2 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 13 Pro Max Screen Replacement, Tape over any cracks: 步骤 3 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Tape over any cracks: 步骤 3 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Tape over any cracks: 步骤 3 中的图像 3,3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • This will keep glass shards contained and provide structural integrity when prying and lifting the screen.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 13 Pro Max Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 3,3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over the left edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use the included tape pad to create a grippier surface.
  5. iPhone 13 Pro Max Screen Replacement: 步骤 5 中的图像 1,2 iPhone 13 Pro Max Screen Replacement: 步骤 5 中的图像 2,2
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 13 Pro Max Screen Replacement: 步骤 6 中的图像 1,2 iPhone 13 Pro Max Screen Replacement: 步骤 6 中的图像 2,2
    • Support your iPhone on a sturdy object before continuing.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 13 Pro Max Screen Replacement, Heat the bottom edge: 步骤 7 中的图像 1,1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  8. iPhone 13 Pro Max Screen Replacement, Insert an opening pick: 步骤 8 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Insert an opening pick: 步骤 8 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Insert an opening pick: 步骤 8 中的图像 3,3
    • Apply a suction handle to the bottom edge of the phone, while avoiding the very edge of the glass.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 13 Pro Max Screen Replacement, Heat the right edge: 步骤 9 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Heat the right edge: 步骤 9 中的图像 2,2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 13 Pro Max Screen Replacement, Separate the right adhesive: 步骤 10 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Separate the right adhesive: 步骤 10 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Separate the right adhesive: 步骤 10 中的图像 3,3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  11. iPhone 13 Pro Max Screen Replacement, Heat the top edge: 步骤 11 中的图像 1,1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 13 Pro Max Screen Replacement, Separate the top adhesive: 步骤 12 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Separate the top adhesive: 步骤 12 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Separate the top adhesive: 步骤 12 中的图像 3,3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  13. iPhone 13 Pro Max Screen Replacement, Screen information: 步骤 13 中的图像 1,1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  14. iPhone 13 Pro Max Screen Replacement, Heat the left edge: 步骤 14 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Heat the left edge: 步骤 14 中的图像 2,2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 13 Pro Max Screen Replacement, Separate the left adhesive: 步骤 15 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Separate the left adhesive: 步骤 15 中的图像 2,2
    • The cables along the left edge are very easy to damage with a pick. Follow this alternate procedure to separate the left adhesive.
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  16. iPhone 13 Pro Max Screen Replacement, Open the iPhone: 步骤 16 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Open the iPhone: 步骤 16 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Open the iPhone: 步骤 16 中的图像 3,3
    • Remove your suction handle from the screen.
    • Open your iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    • Use a Y000 screwdriver to remove the three 1.3 mm screws securing the battery connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  17. iPhone 13 Pro Max Screen Replacement: 步骤 18 中的图像 1,1
    • Remove the battery connector cover.
  18. iPhone 13 Pro Max Screen Replacement, Disconnect the battery: 步骤 19 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Disconnect the battery: 步骤 19 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Disconnect the battery: 步骤 19 中的图像 3,3
    • Use the pointed end of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  19. iPhone 13 Pro Max Screen Replacement, Disconnect the display cable: 步骤 20 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Disconnect the display cable: 步骤 20 中的图像 2,2
    • Use the pointed end a spudger or a clean fingernail to pry the display connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  20. iPhone 13 Pro Max Screen Replacement, Unscrew the front sensor connector cover: 步骤 21 中的图像 1,1
    • Use a Y000 screwdriver to remove two 1.1 mm screws from the front sensor connector cover.
    • Use a Phillips screwdriver to remove the remaining two screws from the front sensor connector cover:
    • One 1.5 mm screw
    • One 1.8 mm screw
  21. iPhone 13 Pro Max Screen Replacement: 步骤 22 中的图像 1,3 iPhone 13 Pro Max Screen Replacement: 步骤 22 中的图像 2,3 iPhone 13 Pro Max Screen Replacement: 步骤 22 中的图像 3,3
    • Remove the front sensor connector cover.
  22. iPhone 13 Pro Max Screen Replacement: 步骤 23 中的图像 1,2 iPhone 13 Pro Max Screen Replacement: 步骤 23 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the front sensor assembly cable connector.
  23. iPhone 13 Pro Max Screen Replacement: 步骤 24 中的图像 1,2 iPhone 13 Pro Max Screen Replacement: 步骤 24 中的图像 2,2
  24. iPhone 13 Pro Max Screen Replacement, Unfasten the front sensor bracket: 步骤 25 中的图像 1,1
    • The remaining steps demonstrate how to transfer the front sensor assembly to a new screen. If your replacement screen comes with the assembly pre-installed, skip these steps.
    • Use a Y000 screwdriver to remove the three 1.4 mm-long screws securing the from sensor assembly bracket.
  25. iPhone 13 Pro Max Screen Replacement, Remove the front sensor bracket: 步骤 26 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Remove the front sensor bracket: 步骤 26 中的图像 2,2
    • Use tweezers, or your fingers, to remove the front sensor assembly bracket.
  26. iPhone 13 Pro Max Screen Replacement, Heat the front sensor assembly: 步骤 27 中的图像 1,1
    • Heat an iOpener and apply it to the top edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display is susceptible to heat damage.
  27. iPhone 13 Pro Max Screen Replacement, Disconnect the ambient light sensor: 步骤 28 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Disconnect the ambient light sensor: 步骤 28 中的图像 2,2
    • Insert an opening pick between the ambient light sensor and its recess in the screen.
    • Pry up with the pick to separate the ambient light sensor from the screen.
  28. iPhone 13 Pro Max Screen Replacement, Disconnect the proximity sensor: 步骤 29 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Disconnect the proximity sensor: 步骤 29 中的图像 2,2
    • Insert an opening pick between the proximity sensor and its recess in the screen.
    • Pry up with the pick to separate the proximity sensor from the screen.
  29. iPhone 13 Pro Max Screen Replacement, Reposition the proximity sensor: 步骤 30 中的图像 1,2 iPhone 13 Pro Max Screen Replacement, Reposition the proximity sensor: 步骤 30 中的图像 2,2
    • Use tweezers, or your fingers, to move the proximity sensor cable away from the screen.
  30. iPhone 13 Pro Max Screen Replacement, Disconnect the microphone: 步骤 31 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Disconnect the microphone: 步骤 31 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Disconnect the microphone: 步骤 31 中的图像 3,3
    • Insert an opening pick under the microphone cable, close to the microphone (the metal rectangle).
    • Slide the opening pick around the perimeter of the microphone to separate its adhesive.
  31. iPhone 13 Pro Max Screen Replacement, Remove the front sensor assembly: 步骤 32 中的图像 1,3 iPhone 13 Pro Max Screen Replacement, Remove the front sensor assembly: 步骤 32 中的图像 2,3 iPhone 13 Pro Max Screen Replacement, Remove the front sensor assembly: 步骤 32 中的图像 3,3
    • At this point, the adhesive may have cooled down. If so, apply a heated iOpener to the assembly for one minute before continuing.
    • Insert an opening pick under the left side of the front sensor assembly.
    • Slide the pick under the assembly to separate it from the frame.
    • Remove the front sensor assembly.
    • When transferring the assembly to a new screen, follow these instructions:
    • Connect the sensors to their slots in the frame to help align the main section of the assembly.
    • Use Tesa tape to re-adhere any sections of the assembly that are no longer sticky.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 13 Pro Max Answers community for troubleshooting help.
22等其他人完成本指南。
Sam Omiotek
于02/25/19注册
60,922 声望
创作了288篇指南
6条评论
There is more to this repair than what you are showing. You aren’t showing us how and what to transfer off the old screen to the new one.
Screen Dr. - 回复
What components will need to be transferred over will depend on the replacement screen you receive. Some come with everything, some don't. I reference the parts iFixit sells when writing guides, and this guide will be updated if necessary once we have these screens in stock.
Sam Omiotek -
how do i aply a new screen
Riley - 回复
thanks for the article. I had a slightly different setup and your step 14 didn't address this and I tore one of the ribbon connectors that goes up tot the camera. I don't know what this is called so i don't know what to order. the ribbon that broke was the one disconnected in step 21. what is this and can it be replaced? thanks!
Art - 回复
Hey. I changed my 13 pro max display, with the true tone and the auto brightness I also see that the display is not getting the maximum brightness level as supposed to. I see a big difference when I open the camera and switch between Video and Photo mode. Can it be fixed? Thank you!
Bincho Stoyanov - 回复
添加评论
浏览统计数据:
过去 24 小时: 91
过去 7 天: 783
过去 30 天: 3,560
总计 55,132
