跳转到主内容
iPhone 12 mini Screen Replacement
你所需要的
  1. iPhone 12 mini Screen Replacement, Remove the pentalobe screws: 步骤 1 中的图像 1,2 iPhone 12 mini Screen Replacement, Remove the pentalobe screws: 步骤 1 中的图像 2,2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
  2. iPhone 12 mini Screen Replacement, Mark your opening picks: 步骤 2 中的图像 1,3 iPhone 12 mini Screen Replacement, Mark your opening picks: 步骤 2 中的图像 2,3 iPhone 12 mini Screen Replacement, Mark your opening picks: 步骤 2 中的图像 3,3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 12 mini Screen Replacement, Tape over any cracks: 步骤 3 中的图像 1,3 iPhone 12 mini Screen Replacement, Tape over any cracks: 步骤 3 中的图像 2,3 iPhone 12 mini Screen Replacement, Tape over any cracks: 步骤 3 中的图像 3,3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 12 mini Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 1,3 iPhone 12 mini Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 2,3 iPhone 12 mini Screen Replacement, Anti-Clamp instructions: 步骤 4 中的图像 3,3
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 12 mini Screen Replacement: 步骤 5 中的图像 1,3 iPhone 12 mini Screen Replacement: 步骤 5 中的图像 2,3 iPhone 12 mini Screen Replacement: 步骤 5 中的图像 3,3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 12 mini Screen Replacement: 步骤 6 中的图像 1,3 iPhone 12 mini Screen Replacement: 步骤 6 中的图像 2,3 iPhone 12 mini Screen Replacement: 步骤 6 中的图像 3,3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 12 mini Screen Replacement, Heat the bottom edge of the phone: 步骤 7 中的图像 1,1
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • Heating the bottom edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
    • If you have trouble during the opening procedure, the adhesive most likely cooled down. Apply more heat to further soften the adhesive.
  8. iPhone 12 mini Screen Replacement, Apply a suction handle: 步骤 8 中的图像 1,2 iPhone 12 mini Screen Replacement, Apply a suction handle: 步骤 8 中的图像 2,2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  9. iPhone 12 mini Screen Replacement, Lift the screen slightly: 步骤 9 中的图像 1,3 iPhone 12 mini Screen Replacement, Lift the screen slightly: 步骤 9 中的图像 2,3 iPhone 12 mini Screen Replacement, Lift the screen slightly: 步骤 9 中的图像 3,3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 12 mini Screen Replacement, Heat the right edge: 步骤 10 中的图像 1,2 iPhone 12 mini Screen Replacement, Heat the right edge: 步骤 10 中的图像 2,2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  11. iPhone 12 mini Screen Replacement, Separate the screen adhesive: 步骤 11 中的图像 1,3 iPhone 12 mini Screen Replacement, Separate the screen adhesive: 步骤 11 中的图像 2,3 iPhone 12 mini Screen Replacement, Separate the screen adhesive: 步骤 11 中的图像 3,3
    • Slide the opening pick around the bottom right corner and along the right edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  12. iPhone 12 mini Screen Replacement, Heat the top edge: 步骤 12 中的图像 1,1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  13. iPhone 12 mini Screen Replacement: 步骤 13 中的图像 1,3 iPhone 12 mini Screen Replacement: 步骤 13 中的图像 2,3 iPhone 12 mini Screen Replacement: 步骤 13 中的图像 3,3
    • The top edge of the display is secured with both glue and clips.
    • Insert your pick underneath the top-right corner of the display panel.
    • Slide the pick around the top right corner. Because of the clips you might encounter some resistance.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Gently pulling the front panel assembly towards the bottom edge of the phone simplifies this step a little.
    • Slide the pick along the top edge and cut any remaining adhesive securing the display.
  14. iPhone 12 mini Screen Replacement, Heat the left edge: 步骤 14 中的图像 1,2 iPhone 12 mini Screen Replacement, Heat the left edge: 步骤 14 中的图像 2,2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  15. iPhone 12 mini Screen Replacement, Screen information: 步骤 15 中的图像 1,1
    • There's a delicate cable along the left edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  16. iPhone 12 mini Screen Replacement, Separate the left adhesive: 步骤 16 中的图像 1,2 iPhone 12 mini Screen Replacement, Separate the left adhesive: 步骤 16 中的图像 2,2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  17. iPhone 12 mini Screen Replacement, Open the iPhone: 步骤 17 中的图像 1,3 iPhone 12 mini Screen Replacement, Open the iPhone: 步骤 17 中的图像 2,3 iPhone 12 mini Screen Replacement, Open the iPhone: 步骤 17 中的图像 3,3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    • Remove the 1.25 mm-long Y000 screw securing the battery & display connector cover bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 12 mini Screen Replacement, Remove the battery and display connector cover: 步骤 19 中的图像 1,2 iPhone 12 mini Screen Replacement, Remove the battery and display connector cover: 步骤 19 中的图像 2,2
    • Use a pair of tweezers to remove the battery & display connector bracket.
    • There are two little hinges on the right edge of the connector bracket. Make sure to align them with their counterparts during reassembly.
  19. iPhone 12 mini Screen Replacement, Disconnect the battery: 步骤 20 中的图像 1,2 iPhone 12 mini Screen Replacement, Disconnect the battery: 步骤 20 中的图像 2,2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  20. iPhone 12 mini Screen Replacement, Disconnect the OLED display cable: 步骤 21 中的图像 1,2 iPhone 12 mini Screen Replacement, Disconnect the OLED display cable: 步骤 21 中的图像 2,2
    • Use a spudger or a clean fingernail to pry the OLED panel cable connector up from its socket on the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. iPhone 12 mini Screen Replacement, Unscrew the front sensor assembly cover: 步骤 22 中的图像 1,2 iPhone 12 mini Screen Replacement, Unscrew the front sensor assembly cover: 步骤 22 中的图像 2,2
    • Remove the five 1 mm-long Y000 screws securing the front sensor assembly cover bracket.
  22. iPhone 12 mini Screen Replacement: 步骤 23 中的图像 1,2 iPhone 12 mini Screen Replacement: 步骤 23 中的图像 2,2
    • Use a pair of tweezers to remove the front sensor assembly bracket.
  23. iPhone 12 mini Screen Replacement, Disconnect the front sensors: 步骤 24 中的图像 1,2 iPhone 12 mini Screen Replacement, Disconnect the front sensors: 步骤 24 中的图像 2,2
    • Use a spudger or a clean fingernail to disconnect the front sensor assembly cable connector.
  24. iPhone 12 mini Screen Replacement, Remove the display assembly: 步骤 25 中的图像 1,1
  25. iPhone 12 mini Screen Replacement, Unscrew the front sensor and speaker assembly: 步骤 26 中的图像 1,2 iPhone 12 mini Screen Replacement, Unscrew the front sensor and speaker assembly: 步骤 26 中的图像 2,2
    • Remove the 1.1 mm-long tri-point Y000 screw.
    • Remove the 1.8 mm-long tri-point Y000 screw.
    • Remove the two 1.6 mm-long Phillips #00 screws.
    • Don't try to remove the front sensor and speaker assembly yet. It's still glued to the rear side of the display panel.
  26. iPhone 12 mini Screen Replacement: 步骤 27 中的图像 1,2 iPhone 12 mini Screen Replacement: 步骤 27 中的图像 2,2
    • Slide the flat end of a spudger underneath the top right corner of the earpiece speaker and fold it to the back.
  27. iPhone 12 mini Screen Replacement, Heat up the top edge of the display: 步骤 28 中的图像 1,1
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for 1-2 minutes, in order to soften the adhesive securing the sensors.
  28. iPhone 12 mini Screen Replacement, Pry up the proximity sensor: 步骤 29 中的图像 1,2 iPhone 12 mini Screen Replacement, Pry up the proximity sensor: 步骤 29 中的图像 2,2
    • Use the pointed end of a spudger to carefully pry the proximity sensor out of its recess.
  29. iPhone 12 mini Screen Replacement: 步骤 30 中的图像 1,2 iPhone 12 mini Screen Replacement: 步骤 30 中的图像 2,2
    • Slide a spudger underneath the wide sensor assembly flex cable to separate it from the screen.
    • Avoid tensioning any of the sensor flex cables during this procedure.
  30. iPhone 12 mini Screen Replacement, Pry up the flood illuminator: 步骤 31 中的图像 1,2 iPhone 12 mini Screen Replacement, Pry up the flood illuminator: 步骤 31 中的图像 2,2
    • Use a spudger or a pair of tweezers to pry the flood illuminator out of its recess.
  31. iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: 步骤 32 中的图像 1,3 iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: 步骤 32 中的图像 2,3 iPhone 12 mini Screen Replacement, Remove the earpiece speaker and front sensor assembly: 步骤 32 中的图像 3,3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the sensors and the microphone. Avoid obstructing them with any adhesive.
    • Flood illuminiator
    • Proximity sensor
    • Microphone
结论
To reassemble your device, follow the above steps in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Check out our iPhone 12 mini Answers community for troubleshooting help.
22等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
191,555 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了15,198篇指南
4条评论
so does apple have to pair it?
Roman - 回复
The only way to pair the new sceen to the phone to retain Tue Tone is to buy a dedicated board that copy the data from the original screen to the new.
Daniele Carminati -
This guide was impeccable! The hardest part is definitely getting the screen glue off. Ended up separating the frame of the screen from the display itself. All worked out in the end though!
Thomas Miller - 回复
Should the phone turn ON and screen work with out speaker/sensor module?
Oleksii Nazaruk - 回复
添加评论
浏览统计数据:
过去 24 小时: 89
过去 7 天: 591
过去 30 天: 2,862
总计 70,316
