跳转到主内容
iPad mini 4 LTE Display Assembly Replacement
Evan Noronha
Evan Noronha4 其他贡献者
最后更新于 August 18, 2023
30分钟 - 1小时
困难
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
prereq only guide for replacing a screen and digitizer, or home button.
你所需要的
工具
查看更多...
  1. iPad mini 4 LTE Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,3 iPad mini 4 LTE Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 2,3 iPad mini 4 LTE Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 3,3
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  2. iPad mini 4 LTE Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the display assembly.
    • To reinstall your display assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
结论
Evan Noronha
于02/05/15注册
226,172 声望
创作了168篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 6
总计 314
