跳转到主内容
加入维修社区 - 创建账户
iPad Air LTE Front Panel Assembly Replacement
你所需要的
  1. iPad Air LTE Front Panel Assembly Replacement, iOpener Heating: 步骤 1 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement, iOpener Heating: 步骤 1 中的图像 2,2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    添加评论
  2. iPad Air LTE Front Panel Assembly Replacement: 步骤 2 中的图像 1,1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    添加评论
  3. iPad Air LTE Front Panel Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    添加评论
  4. iPad Air LTE Front Panel Assembly Replacement, Alternate iOpener heating method: 步骤 4 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement, Alternate iOpener heating method: 步骤 4 中的图像 2,2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    添加评论
  5. iPad Air LTE Front Panel Assembly Replacement, Front Panel: 步骤 5 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement, Front Panel: 步骤 5 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement, Front Panel: 步骤 5 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    添加评论
  6. iPad Air LTE Front Panel Assembly Replacement: 步骤 6 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 6 中的图像 2,2
    • Handling it by the tag, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
    添加评论
  7. iPad Air LTE Front Panel Assembly Replacement: 步骤 7 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 7 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 7 中的图像 3,3
    • While the iPad looks uniform from the outside, there are delicate components under the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Front-facing camera
    • Antennas
    • Display cables
    添加评论
  8. iPad Air LTE Front Panel Assembly Replacement, Anti-Clamp instructions: 步骤 8 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement, Anti-Clamp instructions: 步骤 8 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement, Anti-Clamp instructions: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    询问修复机器人
    添加评论
  9. iPad Air LTE Front Panel Assembly Replacement: 步骤 9 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 9 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 9 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    询问修复机器人
    添加评论
  10. iPad Air LTE Front Panel Assembly Replacement: 步骤 10 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 10 中的图像 2,2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    询问修复机器人
    添加评论
  11. iPad Air LTE Front Panel Assembly Replacement: 步骤 11 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 11 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 11 中的图像 3,3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
    添加评论
  12. iPad Air LTE Front Panel Assembly Replacement: 步骤 12 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 12 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 12 中的图像 3,3
    • Place an opening pick in the gap opened by the suction cup.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
    添加评论
  13. iPad Air LTE Front Panel Assembly Replacement: 步骤 13 中的图像 1,1
    • Reheat and replace the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    添加评论
  14. iPad Air LTE Front Panel Assembly Replacement: 步骤 14 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 14 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 14 中的图像 3,3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    添加评论
  15. iPad Air LTE Front Panel Assembly Replacement: 步骤 15 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 15 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 15 中的图像 3,3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    添加评论
  16. iPad Air LTE Front Panel Assembly Replacement: 步骤 16 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 16 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 16 中的图像 3,3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
    添加评论
  17. iPad Air LTE Front Panel Assembly Replacement: 步骤 17 中的图像 1,1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
    询问修复机器人
    添加评论
  18. iPad Air LTE Front Panel Assembly Replacement: 步骤 18 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 18 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 18 中的图像 3,3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
    添加评论
  19. iPad Air LTE Front Panel Assembly Replacement: 步骤 19 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 19 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 19 中的图像 3,3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front facing camera.
    询问修复机器人
    添加评论
  20. iPad Air LTE Front Panel Assembly Replacement: 步骤 20 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 20 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 20 中的图像 3,3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
    添加评论
  21. iPad Air LTE Front Panel Assembly Replacement: 步骤 21 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 21 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 21 中的图像 3,3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, and then slide it to the corner of the iPad to finish cutting the adhesive on that edge.
    询问修复机器人
    添加评论
  22. iPad Air LTE Front Panel Assembly Replacement: 步骤 22 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 22 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 22 中的图像 3,3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
    询问修复机器人
    添加评论
  23. iPad Air LTE Front Panel Assembly Replacement: 步骤 23 中的图像 1,1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining side of the iPad—along the volume and lock buttons.
    询问修复机器人
    添加评论
  24. iPad Air LTE Front Panel Assembly Replacement: 步骤 24 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 24 中的图像 2,2
    • Slide the opening pick around the top right corner of the iPad, releasing the adhesive there.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
    询问修复机器人
    添加评论
  25. iPad Air LTE Front Panel Assembly Replacement: 步骤 25 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 25 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 25 中的图像 3,3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
    添加评论
  26. iPad Air LTE Front Panel Assembly Replacement: 步骤 26 中的图像 1,1
    • Leave the opening picks in place, and set the reheated iOpener on the home button end of the iPad.
    询问修复机器人
    添加评论
  27. iPad Air LTE Front Panel Assembly Replacement: 步骤 27 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 27 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 27 中的图像 3,3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • The third image shows the two antennas and the home button cavity in the lower case of the iPad.
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
    询问修复机器人
    添加评论
  28. iPad Air LTE Front Panel Assembly Replacement: 步骤 28 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 28 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 28 中的图像 3,3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
    询问修复机器人
    添加评论
  29. iPad Air LTE Front Panel Assembly Replacement: 步骤 29 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 29 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 29 中的图像 3,3
    • Take a new pick and slip it in to the right of the previous pick.
    • Slide across the home button and right-hand antenna using only the very tip to remove the adhesive.
    询问修复机器人
    添加评论
  30. iPad Air LTE Front Panel Assembly Replacement: 步骤 30 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 30 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 30 中的图像 3,3
    • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
    • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
    添加评论
  31. iPad Air LTE Front Panel Assembly Replacement: 步骤 31 中的图像 1,1
    • Reheat and reapply the iOpener to the volume control side of the iPad.
    询问修复机器人
    添加评论
  32. iPad Air LTE Front Panel Assembly Replacement: 步骤 32 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 32 中的图像 2,2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • On the side of the iPad opposite the volume controls, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along the display cable edge.
    • If you encounter a significant amount of resistance, leave the picks in place, reheat, and reapply the iOpener to the problem areas.
    添加评论
  33. iPad Air LTE Front Panel Assembly Replacement: 步骤 33 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 33 中的图像 2,2
    • Lift slowly and gently to further detach the adhesive along the display cable edge.
    添加评论
  34. iPad Air LTE Front Panel Assembly Replacement: 步骤 34 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 34 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 34 中的图像 3,3
    • While supporting the front panel glass, use an opening pick to cut the last of the adhesive.
    • Be very careful not to cut or damage any of the display cables.
    添加评论
  35. iPad Air LTE Front Panel Assembly Replacement: 步骤 35 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 35 中的图像 2,2
    • Once all of the adhesive has been separated, open the glass panel like a page in a book and rest it on your workspace.
    • During reassembly, clean the remains of the adhesive from the case (and the front glass if you are re-using it) with isopropyl alcohol, and replace the adhesive using our display adhesive application guide and pre-cut adhesive strips.
    • It's easy to pinch a flex cable between the front glass and the iPad's frame during reassembly. Be mindful of the flex cables and make sure they gently fold and tuck under the frame. If the folds in a flex cable are pressed completely flat, it may be damaged beyond repair.
    添加评论
  36. iPad Air LTE Front Panel Assembly Replacement, LCD: 步骤 36 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement, LCD: 步骤 36 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement, LCD: 步骤 36 中的图像 3,3
    • Remove any tape obscuring the LCD screws.
    询问修复机器人
    添加评论
  37. iPad Air LTE Front Panel Assembly Replacement: 步骤 37 中的图像 1,1
    • Remove the four Phillips screws securing the LCD:
    • Three 4.0 mm screws
    • One 4.8 mm screw
    询问修复机器人
    添加评论
  38. iPad Air LTE Front Panel Assembly Replacement: 步骤 38 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 38 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 38 中的图像 3,3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    添加评论
  39. iPad Air LTE Front Panel Assembly Replacement: 步骤 39 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 39 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 39 中的图像 3,3
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • Make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
    • You can also use an iFixit battery blocker. Be very careful and don't push the battery blocker underneath the connector with excessive force.
    • Leave the blocker there to prevent the battery connector leads from making contact until you have completed your repairs.
    添加评论
  40. iPad Air LTE Front Panel Assembly Replacement: 步骤 40 中的图像 1,1
    • Remove the three 1.4 mm Phillips screws securing the display cable bracket.
    添加评论
  41. iPad Air LTE Front Panel Assembly Replacement: 步骤 41 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 41 中的图像 2,2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
    添加评论
  42. iPad Air LTE Front Panel Assembly Replacement: 步骤 42 中的图像 1,1
    • Remove the LCD.
    询问修复机器人
    添加评论
  43. iPad Air LTE Front Panel Assembly Replacement, Front Panel Assembly: 步骤 43 中的图像 1,1
    • Remove any tape covering the home button ribbon cable connector.
    询问修复机器人
    添加评论
  44. iPad Air LTE Front Panel Assembly Replacement: 步骤 44 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 44 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 44 中的图像 3,3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
    添加评论
  45. iPad Air LTE Front Panel Assembly Replacement: 步骤 45 中的图像 1,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 45 中的图像 2,3 iPad Air LTE Front Panel Assembly Replacement: 步骤 45 中的图像 3,3
    • Use the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    添加评论
  46. iPad Air LTE Front Panel Assembly Replacement: 步骤 46 中的图像 1,2 iPad Air LTE Front Panel Assembly Replacement: 步骤 46 中的图像 2,2
    在这个步骤中使用的工具:
    Polyimide Tape
    $9.95
    • Remove the front panel assembly.
    • If the home button ribbon cable sticks to the iPad's rear case, don't try to force it. Gently peel it off the case using a pair of tweezers, and then you can fully remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    添加评论
结论
取消:我没有完成这个指南。
143等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
453,482 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,236篇指南
18指南评论
Definitely not for the weak of heart, especially if your screen lost all its integrity when it shattered. You'll be scraping glass splinters off the frame for an hour. Tip: Make sure to scrape off all the black adhesive from the frame of the iPad (and I mean every speck) before putting the new screen down. I apparently missed a spot, and I can't get the screen to seat perfectly within the frame (but close enough; I'm not going back in there). Also, I didn't have much luck with the microwavable tube for softening the adhesive, but I was fortunate to have a heat gun that helped quite a bit.
johnjustinirvine - 回复 分享
I love the ifixit guides and this one is up to their consistently high standards, have to concur with the previous comment though, if your customer brings you a completely trashed digitizer a good number of the steps become obsolete and its down to brute force to remove the adhesive even if you've taped the screen, picks become redundant. One piece of advice that could be incorporated is if the digitizer is beyond repair, just cut the ribbon and be done with it, opening a trashed screen 'like a book' is not necessary, otherwise spot on guys and thanks for making my day easier!
brendon - 回复 分享
I agree with the previous two comments—this guide (or a separate one) should be changed to show to replace a cracked/shattered digitizer. I quickly learned that using the picks was a lost cause and following the guide was near pointless until I got to removing the display.
Pro-tip: don't even bother with the heat gun if the digitizer is shattered. Take the iPad outside, put on a pair of goggles, and just wedge a spudger/tweezers between the adhesive and the glass. Don't worry about damaging the home button or cables, your replacement digitizer probably has them pre-installed...just worry about the camera and not nicking the display. It's going to make a huge mess, but that's why you're outside. Heat it if you want, but I didn't find it necessary.
Jack Burton - 回复 分享
Before you proceed with this — especially if your digitizer is shattered — read through the comments under each step for some helpful hints. Also, one thing that isn't mentioned: DO NOT ATTEMPT TO CLEAN THE INSIDE OF THE DIGITIZER AFTER YOU REMOVE THE PROTECTIVE FILM. From what I can tell, only the outside of the digitizer is made of gorilla glass, and the inside will lightly scratch no matter how soft and clean your cleaning cloth is.
Blair Miller - 回复 分享
I found the guide easy to follow, I completed the repair in half an hour. I found the repair easy to complete BUT i recommend that you use a heat gun over the iOpener tool, as the heat gun is more affective at softening the adhesive making it easier to pull out the little shards of glass. I recommend you update your guide to show a realistic repair with an iPad with a horribly cracked screen.
jguth8 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 134
总计 79,839
