跳转到主内容
Apple AirPort Express Base Station Power Supply Kit
正翻译步骤 12
英语
中文
步骤 12
Apple AirPort Express Base Station Power Supply Kit: 步骤 0 中的图像 1,2 Apple AirPort Express Base Station Power Supply Kit: 步骤 0 中的图像 2,2
  • Solder the pins to the board on the printed side of the PCB.
  • Unsure of how to properly through-hole solder? Check out our technique guide. You can even use a thin piece of wire and practice with a hole on an unused trace.
  • Try to solder quickly and efficiently. Prolonged application of heat to any of the component pins can transfer enough heat to damage it.
在此插入翻译
在此插入翻译
在此插入翻译
您的所有投稿皆享有基于开源创作共享许可协议(CC BY-NC-SA)著作权利
