跳转到主内容
ZTE Lever Screen Replacement
Eric Lilling
Eric Lilling5 其他贡献者
最后更新于 January 10, 2025
45分钟 - 1小时
中等
效率不高但可能有用的步骤
Replacing the screen of your ZTE Lever smartphone can restore its functionality and aesthetics, saving you the cost of a full device replacement. Whether the screen is cracked, unresponsive, or malfunctioning, this guide will walk you through the steps to safely and effectively replace it.
Before beginning, ensure you have the following tools and materials:
  • Adhesive strips or glue for reassembling. This guide might be helpful if you don't have adhesive strips included with your new screen.
  • A heat gun or hair dryer (for loosening adhesive). This guide provides useful tips for how to use a heat gun to loosen adhesive safely.
This process requires careful handling of small components and adherence to safety precautions, especially when dealing with fragile parts and adhesives. If you're confident in your skills, let’s get started!
Before you begin, make sure your phone is off and unplugged from the charger.
你所需要的
工具
查看更多...
  1. ZTE Lever Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Screen Replacement: 步骤 2 中的图像 1,2 ZTE Lever Screen Replacement: 步骤 2 中的图像 2,2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Screen Replacement: 步骤 3 中的图像 1,2 ZTE Lever Screen Replacement: 步骤 3 中的图像 2,2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Screen Replacement: 步骤 4 中的图像 1,2 ZTE Lever Screen Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Screen Replacement: 步骤 5 中的图像 1,1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Screen Replacement, Volume Buttons: 步骤 6 中的图像 1,1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Screen Replacement: 步骤 7 中的图像 1,3 ZTE Lever Screen Replacement: 步骤 7 中的图像 2,3 ZTE Lever Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Screen Replacement: 步骤 8 中的图像 1,2 ZTE Lever Screen Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Screen Replacement: 步骤 9 中的图像 1,2 ZTE Lever Screen Replacement: 步骤 9 中的图像 2,2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Screen Replacement, Power Button: 步骤 10 中的图像 1,1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Screen Replacement: 步骤 11 中的图像 1,2 ZTE Lever Screen Replacement: 步骤 11 中的图像 2,2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Screen Replacement, Motherboard: 步骤 12 中的图像 1,2 ZTE Lever Screen Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Screen Replacement: 步骤 13 中的图像 1,1
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Screen Replacement: 步骤 14 中的图像 1,2 ZTE Lever Screen Replacement: 步骤 14 中的图像 2,2
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Screen Replacement: 步骤 15 中的图像 1,1
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Screen Replacement: 步骤 16 中的图像 1,3 ZTE Lever Screen Replacement: 步骤 16 中的图像 2,3 ZTE Lever Screen Replacement: 步骤 16 中的图像 3,3
  17. ZTE Lever Screen Replacement: 步骤 17 中的图像 1,1
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Screen Replacement: 步骤 18 中的图像 1,1
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Screen Replacement: 步骤 19 中的图像 1,3 ZTE Lever Screen Replacement: 步骤 19 中的图像 2,3 ZTE Lever Screen Replacement: 步骤 19 中的图像 3,3
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Screen Replacement: 步骤 20 中的图像 1,1
    • Remove the motherboard with your fingers.
  21. ZTE Lever Screen Replacement, Screen: 步骤 21 中的图像 1,2 ZTE Lever Screen Replacement, Screen: 步骤 21 中的图像 2,2
    • Using the iFixit opening tool, pry off the screen from the case.
    • Be careful not to crack the case.
  22. ZTE Lever Screen Replacement: 步骤 22 中的图像 1,3 ZTE Lever Screen Replacement: 步骤 22 中的图像 2,3 ZTE Lever Screen Replacement: 步骤 22 中的图像 3,3
    • Slide the 2 ribbon cables through their respective holes before separating the case from the screen.
    • Gently lift up the case from the screen.
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 271
