跳转到主内容
YCCTEAM YCC-SW4001 ABXY Buttons Replacement
Sam Borwick
Sam Borwick3 其他贡献者
最后更新于 May 31, 2024
20分钟
简单
The ABXY buttons are important because they are the primary method of controlling inputs to a game or menu. These buttons are easy to take out after taking off the front cover, so they are popular to customize and modify. If you are experiencing ABXY buttons that stick or are unresponsive, it may be time to clean or replace them.
In replacing the ABXY buttons, you will need a Phillips #1 screwdriver, an opening pick, and a pair of tweezers.
If the ABXY buttons (A, B, X, Y, D-Pad, +, –, HOME, and Screenshot buttons) on your YCCTEAM YCC-SW4001 have debris under them, are broken, or are not functioning properly, you can follow this guide to clean or replace them.
你所需要的
工具
查看更多...
  1. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, Front Case: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
  2. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 2 中的图像 1,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 2 中的图像 2,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 2 中的图像 3,3
    • Use an opening pick to pry the back cover off of the controller.
  3. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
  4. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 4 中的图像 1,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 4 中的图像 2,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 4 中的图像 3,3
    • Slightly lift the front case.
    • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
  5. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 5 中的图像 1,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 5 中的图像 2,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 5 中的图像 3,3
    • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
    • The black flap holds the white ribbon cable in place.
  6. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 6 中的图像 1,2 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 6 中的图像 2,2
    • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
  7. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove the front case.
  8. YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: 步骤 8 中的图像 1,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: 步骤 8 中的图像 2,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement, ABXY Buttons: 步骤 8 中的图像 3,3
    • Isolate the front cover.
    • Flip over the front cover and remove the four 5.77 mm screws from the back of the front cover using the Phillips #1 Screwdriver.
  9. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 9 中的图像 1,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 9 中的图像 2,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 9 中的图像 3,3
    • Lift the circuit board from the front cover to expose the back of the buttons.
  10. YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 10 中的图像 1,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 10 中的图像 2,3 YCCTEAM YCC-SW4001 ABXY Buttons Replacement: 步骤 10 中的图像 3,3
    • Remove the rubber caps and the button caps by either dumping them out or taking them out by hand.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 130
