跳转到主内容
Wii U GamePad Battery Replacement
Kim Arre
Kim Arre8 其他贡献者
最后更新于 September 8, 2024
3分钟
简单
Use this guide to replace the battery in your Wii U GamePad.
你所需要的
配件
工具
查看更多...
  1. Wii U GamePad Battery Replacement, Battery: 步骤 1 中的图像 1,2 Wii U GamePad Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Battery Replacement: 步骤 2 中的图像 1,3 Wii U GamePad Battery Replacement: 步骤 2 中的图像 2,3 Wii U GamePad Battery Replacement: 步骤 2 中的图像 3,3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
结论
27等其他人完成本指南。
Kim Arre
于01/11/13注册
5,265 声望
创作了8篇指南
团队
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G20
5 名成员
创作了40篇指南
8指南评论
I only see two pins on most 3rd party rechargeable Li-Ion batteries. What is the pinout for the factory supplied battery? I would like to replace the battery with a similar 3.7v Li-Ion battery from somewhere like adafruit.
roof tip - 回复
I found an answer to my first question. My follow up question is if you can use a battery with only two charging pins and not the temp sensor pins?
roof tip - 回复
There's no reason you can't but without the temp sensor you must be cautions if your battery does over heat because it can lead to damages on the touchscreen as well.
Steven Chiu - 回复
Why does Nintendo mention a size #0 screwdriver while iFixit says #00?
proof: http://en-americas-support.nintendo.com/...
"•Use a crosshead style, size #0 screwdriver to avoid damage to the screw or threads"
"2.Loosen the battery cover screws with a crosshead style, size #0 screwdriver."
/a confused person
Chris - 回复
The size #00 is just a little smaller than the #0. When we wrote these guides, we used whatever worked for us. Either should work, but generally you should use the largest that will work to avoid stripping the screw.
Kim Arre -
can't you just use any lithium battery like this?? It shouldn't have to be a special exclusive device only battery.
jasonmg99 - 回复
Great idea! Maybe you can try it out and let us know if it works or not!
stevenychiu -
I have trouble unscrewing the screws. I do need to lube the screws and if so what lube do I use
Benjydenjy - 回复
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 172
过去 30 天: 797
总计 38,454
