跳转到主内容
Verizon Ellipsis Jetpack MHS800L Screen Replacement
Richard J Porras
Richard J Porras5 其他贡献者
最后更新于 March 1, 2023
5 - 10 分钟
简单
需要更好的图片
What you can expect from this guide is a step by step process on how to remove the LCD display screen on a Verizon Ellipsis Jetpack MHS800L.
你所需要的
工具
查看更多...
  1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: 步骤 1 中的图像 1,3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: 步骤 1 中的图像 2,3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: 步骤 1 中的图像 3,3
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 2 中的图像 1,3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 2 中的图像 2,3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Phillips #00 Screwdriver
    $5.49
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 3 中的图像 1,1
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
  5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 5 中的图像 1,1
    • Once the cover is off, this is what your device will look like.
  6. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: 步骤 6 中的图像 1,2 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: 步骤 6 中的图像 2,2
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
  7. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 7 中的图像 1,2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
  8. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
  9. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 9 中的图像 1,1
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
  10. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: 步骤 10 中的图像 1,3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: 步骤 10 中的图像 2,3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: 步骤 10 中的图像 3,3
    • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
  11. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 11 中的图像 1,2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    • Using the Tweezers gently coax the display data cable out of circuit board connector.
    • Do not squeeze the display data cable to hard you may damage it and cause a short.
  12. Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 12 中的图像 1,2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
结论
另外一个人完成了本指南。
团队
IUPUI, Team 3-3, Baechle Spring 2016 IUPUI, Team 3-3, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S3G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,195
