跳转到主内容
Toshiba Satellite C850 Keyboard Replacement
ZFix
ZFix 另一个贡献者
最后更新于 December 27, 2022
5 - 10 分钟
简单
社区贡献指南
How to replace the Keyboard on Toshiba Satellite, series 850.
The video manual is for cleaning the cooling system, but you can follow it, because at the beginning you can see how to disassemble the keyboard.
Please SUBSCRIBE to my channel ツ
你所需要的
工具
视频概述
  1. Toshiba Satellite C850 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Toshiba Satellite C850 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Switch-off the laptop and remove the battery.
  2. Toshiba Satellite C850 Keyboard Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C850 Keyboard Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C850 Keyboard Replacement: 步骤 2 中的图像 3,3
    • The Keyboard is held by 7x locking clips. Use cutter and plastic tools to unlock them.
    I was disassembling a c-850 laptop but it was obvious that the kb is firmly fixed! Finally i found there are four screws on the top part of kb, hidden under a plastic strip . I’d add a photo…but no “attach” button here
    asaf c - 回复
  3. Toshiba Satellite C850 Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite C850 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Disconnect the old Keyboard and you are ready to install the new one.
    • To remove or re-insert the keyboard ribbon, simply flip the locking clip upwards to unlock and downwards to lock the ribbon. Alternatively, you may pull it outwards with a fingernail.
    • Please SUBSCRIBE to my channel ツ
结论
15等其他人完成本指南。
ZFix
于12/09/13注册
194,222 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
327 名成员
创作了1,672篇指南
3指南评论
Where does the 4-pin ribbon cable for a backlit keyboard connect?
thomja1 - 回复
I want new keyboard, where can i get that ?
Eswara Prasad - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 46
总计 13,361
