跳转到主内容
Toshiba Satellite C850 Keyboard Replacement
你所需要的
视频概述
  1. Toshiba Satellite C850 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Toshiba Satellite C850 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Switch-off the laptop and remove the battery.
  2. Toshiba Satellite C850 Keyboard Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite C850 Keyboard Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite C850 Keyboard Replacement: 步骤 2 中的图像 3,3
    • The Keyboard is held by 7x locking clips. Use cutter and plastic tools to unlock them.
    I was disassembling a c-850 laptop but it was obvious that the kb is firmly fixed! Finally i found there are four screws on the top part of kb, hidden under a plastic strip . I’d add a photo…but no “attach” button here
    asaf c - 回复
  3. Toshiba Satellite C850 Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite C850 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Disconnect the old Keyboard and you are ready to install the new one.
    • To remove or re-insert the keyboard ribbon, simply flip the locking clip upwards to unlock and downwards to lock the ribbon. Alternatively, you may pull it outwards with a fingernail.
    • Please SUBSCRIBE to my channel ツ
结论
15等其他人完成本指南。
ZFix
于12/09/13注册
194,135 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
326 名成员
创作了1,670篇指南
3指南评论
Where does the 4-pin ribbon cable for a backlit keyboard connect?
thomja1 - 回复
I want new keyboard, where can i get that ?
Eswara Prasad - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 38
总计 13,351
