跳转到主内容
Sony Cyber-shot DSC-W730 Control board Replacement
Douglas Howe
Douglas Howe4 其他贡献者
最后更新于 May 7, 2024
15分钟
简单
This could be a solution to the buttons on the back of the camera not working. This is an easy replacement. Just be careful with the ribbons.
你所需要的
工具
查看更多...
  1. Sony Cyber-shot DSC-W730 Control board Replacement, Removing the Case: 步骤 1 中的图像 1,3 Sony Cyber-shot DSC-W730 Control board Replacement, Removing the Case: 步骤 1 中的图像 2,3 Sony Cyber-shot DSC-W730 Control board Replacement, Removing the Case: 步骤 1 中的图像 3,3
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 2 中的图像 1,3 Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 2 中的图像 2,3 Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 2 中的图像 3,3
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 3 中的图像 2,2
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 4 中的图像 1,2 Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 4 中的图像 2,2
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 5 中的图像 1,3 Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 5 中的图像 2,3 Sony Cyber-shot DSC-W730 Control board Replacement: 步骤 5 中的图像 3,3
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Control board Replacement, LCD Control Board: 步骤 6 中的图像 1,2 Sony Cyber-shot DSC-W730 Control board Replacement, LCD Control Board: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
结论
Douglas Howe
于01/08/15注册
510 声望
创作了4篇指南
团队
USF Tampa, Team 9-4, Blackwell Winter 2015 USF Tampa, Team 9-4, Blackwell Winter 2015 的会员
USFT-BLACKWELL-W15S9G4
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 652
