Sony Cyber-shot DSC-W55 Front Case Replacement
简介
转到步骤 1We are going to explain the steps needed and what is necessary in order to replace a broken front cover for this camera.
你所需要的
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
另外一个人完成了本指南。
