跳转到主内容
Sony Cyber-shot DSC-HX1 Battery Replacement
Brianna Greenlaw
Brianna Greenlaw3 其他贡献者
最后更新于 January 13, 2021
3 - 5 分钟
非常容易
This guide gives a simple step-by-step process for removing and/or replacing the battery. Battery removal is required for most other repairs of this device.
  1. Sony Cyber-shot DSC-HX1 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Battery Replacement: 步骤 2 中的图像 1,1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Battery Replacement: 步骤 3 中的图像 1,2 Sony Cyber-shot DSC-HX1 Battery Replacement: 步骤 3 中的图像 2,2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
结论
To reassemble your device, insert the new battery in the compartment, making sure that your battery has the correct orientation, then follow these instructions in reverse order.
Brianna Greenlaw
于04/06/15注册
1,217 声望
创作了5篇指南
团队
Cal Poly, Team 17-3, Forte Spring 2015 Cal Poly, Team 17-3, Forte Spring 2015 的会员
CPSU-FORTE-S15S17G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 18
过去 30 天: 33
总计 1,350
