跳转到主内容
Samsung Galaxy Watch4 Classic Battery Replacement
Adriana Zwink
Adriana Zwink4 其他贡献者
最后更新于 April 3, 2025
20 - 45 分钟
中等
特色指南
Use this guide to replace a worn-out or dead battery in your Galaxy Watch4 Classic.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your Galaxy Watch4 Classic. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
你所需要的
配件
工具
查看更多...
  1. Samsung Galaxy Watch4 Classic Battery Replacement, Power down your watch: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Battery Replacement, Unscrew the back cover: 步骤 2 中的图像 1,1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
  3. Samsung Galaxy Watch4 Classic Battery Replacement, Pry open the back cover: 步骤 3 中的图像 1,2 Samsung Galaxy Watch4 Classic Battery Replacement, Pry open the back cover: 步骤 3 中的图像 2,2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the sensor flex cable: 步骤 4 中的图像 1,2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the sensor flex cable: 步骤 4 中的图像 2,2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the back cover: 步骤 5 中的图像 1,1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the hall sensor flex cable: 步骤 6 中的图像 1,2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the hall sensor flex cable: 步骤 6 中的图像 2,2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
  7. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the display flex cable: 步骤 7 中的图像 1,2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the display flex cable: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the side buttons: 步骤 8 中的图像 1,2 Samsung Galaxy Watch4 Classic Battery Replacement, Disconnect the side buttons: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the crown button flex cable.
  9. Samsung Galaxy Watch4 Classic Battery Replacement, Unscrew the motherboard: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  10. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: 步骤 10 中的图像 1,3 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: 步骤 10 中的图像 2,3 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the motherboard: 步骤 10 中的图像 3,3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
  11. Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: 步骤 11 中的图像 1,3 Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: 步骤 11 中的图像 2,3 Samsung Galaxy Watch4 Classic Battery Replacement, Lever up the battery: 步骤 11 中的图像 3,3
    • The battery is held in place with light adhesive.
    • Place the flat end of a spudger in the small gap between the plastic frame and the battery, opposite to the display cable.
    • Carefully lever the battery up and out of its recess.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Don't try to remove the battery completely yet, as its connector is still adhered to the core assembly.
  12. Samsung Galaxy Watch4 Classic Battery Replacement, Remove the battery: 步骤 12 中的图像 1,2 Samsung Galaxy Watch4 Classic Battery Replacement, Remove the battery: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift the battery up a little in order to access its glued down connector cable.
    • Use a pair of blunt tweezers to lift up the battery connector which is secured with some light adhesive.
    • You will most likely be able to re-use the adhesive to fix the new battery in place. If not, replace it with double sided or pre-cut adhesive tape.
    • Remove the battery.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
16等其他人完成本指南。
Adriana Zwink
于12/18/19注册
56,666 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,631篇指南
5指南评论
What kind of battery does it use?
Dylan - 回复
The directions are perfect! I had very little issue following your instructions.
One point I would make is that there seems to be more of an available gap to pry the back off of the watch located between the pairs of wristband spurs where there is very little gap on the sides. After almost 20 minutes of trying to get the little plastic tool to work the back off, I looked closely at the area between the spurs and it looked more promising. A couple of probes with the tool, and the the back started right off. The rest is history. Thanks!!!
Rufus T. Montgomery - 回复
Is there any adhesive applied for the water resistance while installation of the battery ?
Wasabi - 回复
Instructions are perfect.
Evidence of water damage though in mine, so sprayed the crusty bits with electrical solvent cleaner. Nothing to loose.
It's powered back up with the new battery, so see how long it lasts.
If it gives problems time for a new watch.
Won't be wearing it again in the shower though.
Michael Heathcote - 回复
It works better to first heat the watch slightly on the back with a hair dryer in step 3. then the rubber waterproof ring will come loose a bit and you can carefully open it. be careful not to damage the ring.
Alc0 - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 76
过去 30 天: 424
总计 14,082
