跳转到主内容
Samsung Galaxy A53 5G Back Cover Replacement
Adriana Zwink
Adriana Zwink 另一个贡献者
最后更新于 July 18, 2024
15 - 30 分钟
中等
Use this guide to replace a damaged back cover on your Samsung Galaxy A53 5G.
You’ll need to replace the adhesive on the back cover when reassembling to seal the device shut. Depending on that seal, the device might lose its water protection.
You'll need replacement adhesive to complete this repair.
你所需要的
配件
工具
查看更多...
  1. Samsung Galaxy A53 5G Back Cover Replacement, Heat the back cover: 步骤 1 中的图像 1,1
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A53 5G Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 1,2 Samsung Galaxy A53 5G Back Cover Replacement, Insert an opening pick: 步骤 2 中的图像 2,2
    • Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
  3. Samsung Galaxy A53 5G Back Cover Replacement, Slice the adhesive: 步骤 3 中的图像 1,3 Samsung Galaxy A53 5G Back Cover Replacement, Slice the adhesive: 步骤 3 中的图像 2,3 Samsung Galaxy A53 5G Back Cover Replacement, Slice the adhesive: 步骤 3 中的图像 3,3
    • Slide the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy A53 5G Back Cover Replacement, Slice the adhesive: 步骤 4 中的图像 1,3 Samsung Galaxy A53 5G Back Cover Replacement, Slice the adhesive: 步骤 4 中的图像 2,3 Samsung Galaxy A53 5G Back Cover Replacement, Slice the adhesive: 步骤 4 中的图像 3,3
    • Insert a second opening pick at the top right edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A53 5G Back Cover Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy A53 5G Back Cover Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy A53 5G Back Cover Replacement: 步骤 5 中的图像 3,3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the bottom edge of your phone to slice the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A53 5G Back Cover Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy A53 5G Back Cover Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy A53 5G Back Cover Replacement: 步骤 6 中的图像 3,3
    • Insert a fourth opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  7. Samsung Galaxy A53 5G Back Cover Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy A53 5G Back Cover Replacement: 步骤 7 中的图像 2,2
    • Insert a fifth opening pick at the top left corner.
    • Slide the opening pick along the top edge of the back cover to slice the remaining adhesive.
  8. Samsung Galaxy A53 5G Back Cover Replacement, Remove the back cover: 步骤 8 中的图像 1,1
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
结论
3等其他人完成本指南。
Adriana Zwink
于12/18/19注册
56,528 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,537篇指南
2条评论
Where the heck do you get one of these back pieces? No one has them.
Anna Dailey - 回复
Magnifique merci pour les incormations
Salim - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 107
过去 30 天: 396
总计 9,571
