跳转到主内容
Poin2 Chromebook 11 Charging Port Replacement
Jesse Johnson
Jesse Johnson4 其他贡献者
最后更新于 May 7, 2024
15分钟
中等
When a Chromebook is plugged into an outlet with a working adapter, but the device will neither charge or power on, this is a sign that the charging port is damaged and needs to be replaced. This guide shows how to replace a defective charging port for a Poin2 Chromebook 11.
你所需要的
工具
查看更多...
  1. Poin2 Chromebook 11 Charging Port Replacement, Battery: 步骤 1 中的图像 1,2 Poin2 Chromebook 11 Charging Port Replacement, Battery: 步骤 1 中的图像 2,2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
    Rubber feet at the base DO have screws. I broke mine not knowing this.
    Marty - 回复
  2. Poin2 Chromebook 11 Charging Port Replacement: 步骤 2 中的图像 1,3 Poin2 Chromebook 11 Charging Port Replacement: 步骤 2 中的图像 2,3 Poin2 Chromebook 11 Charging Port Replacement: 步骤 2 中的图像 3,3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Charging Port Replacement: 步骤 3 中的图像 1,3 Poin2 Chromebook 11 Charging Port Replacement: 步骤 3 中的图像 2,3 Poin2 Chromebook 11 Charging Port Replacement: 步骤 3 中的图像 3,3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Charging Port Replacement: 步骤 4 中的图像 1,2 Poin2 Chromebook 11 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Charging Port Replacement, Charging Port: 步骤 6 中的图像 1,2 Poin2 Chromebook 11 Charging Port Replacement, Charging Port: 步骤 6 中的图像 2,2
    • The changing port is located on the upper-right corner of the computer.
    • Disconnect the charging port from the motherboard using a spudger to push the 4-wire connector out from the port.
  7. Poin2 Chromebook 11 Charging Port Replacement: 步骤 7 中的图像 1,2 Poin2 Chromebook 11 Charging Port Replacement: 步骤 7 中的图像 2,2
    • Remove silver tape covering hinge.
  8. Poin2 Chromebook 11 Charging Port Replacement: 步骤 8 中的图像 1,2 Poin2 Chromebook 11 Charging Port Replacement: 步骤 8 中的图像 2,2
    • The metal hinge at the top right corner must be lifted to access the charging port.
    • Use a Phillips #0 screwdriver and remove the two 7mm screws from the hinge.
  9. Poin2 Chromebook 11 Charging Port Replacement: 步骤 9 中的图像 1,1
    • Pry the metal hinge up, until it sits perpendicular to the motherboard.
    • The metal hinge is a tight fit and requires careful strength when lifting.
  10. Poin2 Chromebook 11 Charging Port Replacement: 步骤 10 中的图像 1,2 Poin2 Chromebook 11 Charging Port Replacement: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to gently pull the charging port out of the frame.
    Have a chrome book 11 C81C13 / made 2019 . The port is captive"? Connected to almost everything and wifi etc; function's work"! Network on mobile data work “ yet if I try to connect the mobile network on the cell phone ? It with bring all function's displaying that there is signal frequency's etc but the display of the actual funtion. [ Internet does not appear on the computer screen ! ] If I go into a business or use some one other fell mobile data it work's ?. Recommendations".
    romansrnoel@gmail.com - 回复
结论
4等其他人完成本指南。
2指南评论
Great, Now where can I find this part to fix my laptop???
marrowii - 回复
where do I buy the new port???
rhena9 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 54
总计 7,885
