跳转到主内容
PlayStation Optical Drive Replacement
Craig Lloyd
Craig Lloyd8 其他贡献者
最后更新于 March 25, 2025
10 - 20 分钟
中等
特色指南
If your PlayStation is having trouble reading discs, the optical drive may need to be replaced. The optical drive is prone to fail on earlier models due to plastic rails warping over time. This guide will take you through the process of replacing the optical drive, which includes the laser and motor assemblies.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
你所需要的
工具
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. PlayStation Optical Drive Replacement, Open the Console: 步骤 1 中的图像 1,1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    The SCPH-9001 model does not have the Parallel Port panel to remove.
    Aislinn - 回复
  2. PlayStation Optical Drive Replacement: 步骤 2 中的图像 1,2 PlayStation Optical Drive Replacement: 步骤 2 中的图像 2,2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Optical Drive Replacement, Remove the Optical Drive: 步骤 3 中的图像 1,2 PlayStation Optical Drive Replacement, Remove the Optical Drive: 步骤 3 中的图像 2,2
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
    I broke the optical drive power cable’s socket off from the motherboard! How to put it back on?
    B H - 回复
    Please try not to pull via the wires as you run the risk of breaking the cable, in which if you have a replacement reader like mine you will need this cable again as it didn’t come with one. I recommend wiggling it from each side. Seems to work for me.
    Jamie Sylver - 回复
  4. PlayStation Optical Drive Replacement: 步骤 4 中的图像 1,3 PlayStation Optical Drive Replacement: 步骤 4 中的图像 2,3 PlayStation Optical Drive Replacement: 步骤 4 中的图像 3,3
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
    While I was pulling this cable, the whole connector came off the motherboard (the white part that's supposed do stay on the motherboard)... How can I fix it?
    Zvezdan Disic - 回复
    Do I solder it or what?
    Zvezdan Disic - 回复
    Same exact problem with pulling the entire connector off the motherboard. What do i do?
    Aaron Loyd - 回复
    Yes, could try clean and re-solder, and do a proper re-work job.
    leafybye - 回复
    help! i just had the same problem! someone was able to solve it ???
    Jack - 回复
  5. PlayStation Optical Drive Replacement: 步骤 5 中的图像 1,2 PlayStation Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Lift the optical drive straight up to remove it.
结论
49等其他人完成本指南。
Craig Lloyd
于02/10/16注册
39,058 声望
创作了82篇指南
4指南评论
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
leafybye - 回复
What about model SCPH-5501?
janis Nasuta - 回复
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
The invader 2 - 回复
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
John Reeves - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 100
过去 30 天: 530
总计 68,552
