简介
If your PlayStation is having trouble reading discs, the optical drive may need to be replaced. The optical drive is prone to fail on earlier models due to plastic rails warping over time. This guide will take you through the process of replacing the optical drive, which includes the laser and motor assemblies.
Note: This repair is demonstrated on a SCPH-1001 model. The process may differ slightly if you have a later model.
你所需要的
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
Please try not to pull via the wires as you run the risk of breaking the cable, in which if you have a replacement reader like mine you will need this cable again as it didn’t come with one. I recommend wiggling it from each side. Seems to work for me.
Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
While I was pulling this cable, the whole connector came off the motherboard (the white part that's supposed do stay on the motherboard)... How can I fix it?
Do I solder it or what?
Same exact problem with pulling the entire connector off the motherboard. What do i do?
Aaron Loyd - 回复
49等其他人完成本指南。
4条评论
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
What about model SCPH-5501?
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
The SCPH-9001 model does not have the Parallel Port panel to remove.
Aislinn - 回复
