跳转到主内容
Opening the Huawei Watch 3
Tobias Isakeit
Tobias Isakeit2 其他贡献者
最后更新于 July 30, 2024
10 - 15 分钟
中等
Use this guide to open the Huawei Watch 3 and remove the back cover.
你所需要的
工具
查看更多...
    • User your fingernail to pull the small metal pin on each wrist band towards the inside. This unlocks the wrist bands from the body of the watch.
    • Remove the wrist bands.
  1. Opening the Huawei Watch 3, Remove the four Torx screws: 步骤 2 中的图像 1,1
    • Use a Torx T3 screwdriver to remove the four 4 mm-long screws on the back of the Huawei Watch 3.
  2. Opening the Huawei Watch 3, Pry the back cover open: 步骤 3 中的图像 1,3 Opening the Huawei Watch 3, Pry the back cover open: 步骤 3 中的图像 2,3 Opening the Huawei Watch 3, Pry the back cover open: 步骤 3 中的图像 3,3
    • Locate the small notch at the top of the back cover.
    • Use a Jimmy to pry open the back cover by twisting it.
    • Using a sharp metal tool might cause cosmetic damage to the watch case. Covering the tool with a nitril glove can minimize the damage.
    • Don’t remove the back cover just yet. It is still connected to the motherboard with a flex cable.
  3. Opening the Huawei Watch 3, Loosen the back cover gasket: 步骤 4 中的图像 1,2 Opening the Huawei Watch 3, Loosen the back cover gasket: 步骤 4 中的图像 2,2
    • Insert the tip of an opening pick between the back cover and the case.
    • Slide the opening pick around the back cover to loosen the gasket from the back cover.
  4. Opening the Huawei Watch 3, Lift the back cover: 步骤 5 中的图像 1,3 Opening the Huawei Watch 3, Lift the back cover: 步骤 5 中的图像 2,3 Opening the Huawei Watch 3, Lift the back cover: 步骤 5 中的图像 3,3
    • There is a ribbon cable running from the back cover to the motherboard.
    • Use an opening pick or your fingers to carefully lift the back cover open.
    • Flip the back cover open away from the crown.
    • You can prop up the back cover to minimize the stress on the ribbon cable.
  5. Opening the Huawei Watch 3, Remove the battery bracket screw: 步骤 6 中的图像 1,1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the battery bracket.
  6. Opening the Huawei Watch 3, Remove the battery bracket: 步骤 7 中的图像 1,3 Opening the Huawei Watch 3, Remove the battery bracket: 步骤 7 中的图像 2,3 Opening the Huawei Watch 3, Remove the battery bracket: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • User a pair of tweezers to lift the top of the battery bracket free from its screw socket.
    • Unhook the opposite side of the bracket and remove it.
  7. Opening the Huawei Watch 3, Unplug the battery connector: 步骤 8 中的图像 1,2 Opening the Huawei Watch 3, Unplug the battery connector: 步骤 8 中的图像 2,2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    • The battery connector is the smallest of the three connectors.
  8. Opening the Huawei Watch 3, Remove the sensor bracket screw: 步骤 9 中的图像 1,1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the sensor bracket.
  9. Opening the Huawei Watch 3, Remove the sensor bracket: 步骤 10 中的图像 1,3 Opening the Huawei Watch 3, Remove the sensor bracket: 步骤 10 中的图像 2,3 Opening the Huawei Watch 3, Remove the sensor bracket: 步骤 10 中的图像 3,3
    • User a pair of tweezers to move the top of the sensor bracket free from a small latch near the case by rotating in inwards.
  10. Opening the Huawei Watch 3, Unplug the sensor connector: 步骤 11 中的图像 1,3 Opening the Huawei Watch 3, Unplug the sensor connector: 步骤 11 中的图像 2,3 Opening the Huawei Watch 3, Unplug the sensor connector: 步骤 11 中的图像 3,3
    • Use the tip of a spudger to pry up and disconnect the sensor connector.
    • Remove the back cover.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our https://www.ifixit.com/Answers/Device/Hu... for help.
另外一个人完成了本指南。
Tobias Isakeit
于03/31/14注册
124,507 声望
创作了189篇指南
团队
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 的会员
Business
1 名成员
创作了1,132篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 147
总计 2,925
