简介
If you need to replace the battery in your OnePlus 9 Pro this guide is for you.
Batteries can be dangerous because of the chemicals they hold and their ability to catch fire or explode, so exercising precaution should be the number one priority in each step.
你所需要的
Use an opening pick or tweezers to carefully peel back the adhesive on the bottom of the wireless charging module.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
12等其他人完成本指南。
1指南评论
Battery s.b. glued and clamped in place so that vapor chamber will use battery to further dissipate CPU heat.
