简介
欢迎!您的手柄中的电池不耐用了?那您一定是在找更换 Nintendo Switch Pro 手柄电池的指南,这样您来对地方了!在下面,您将找到有关更换手柄电池的说明,请仔细阅读,并按照从步骤一到步骤六的顺序依次进行操作。
Switch Pro 手柄使用的是 JIS 螺丝,拆卸时请勿使用 iFixit 的 Phillips 螺丝刀,否则可能导致滑丝,损坏螺丝钉。
注意: Switch Pro 手柄在未正确与 Switch 主机同步的情况下,也是无法正常充电的。因此需要先确定电池是否有故障并需要更换:您可以先重新同步手柄,并在插入电源时在 Switch 手柄菜单中检查它是否可以正常充电。
注意:为了安全起见,处理任何发生膨胀的电池时都应格外小心。有关如何识别、处置膨胀电池的方法,请点击下面的链接查看。
你所需要的
如需重新组装设备的话,请按照相反的顺序进行操作。
若要发挥电池的最佳效果,请在完成本指南操作后参考:calibrate your newly installed battery
如您需要回收电子设备请参考: R2 or e-Stewards certified recycler
维修不如意?尝试排除故障: basic troubleshooting
或通过Answers community向我们寻求帮助。
37等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
12条评论
easy peasy only have to recycle battery
Where can I buy genuine ctr-003 batteries in germany/europe?
You can buy them directly in the iFixit Europe or in your case in the Germany store.
Guide facile à suivre et rapide à exécuter. Merci!
Thanks for sharing this "how to" guide. Upon replacing my battery I realize that there was a malfunctioning into the USB-C port which was not charging batteries through the controller port. I'm writing this in order to alert some people that the problem with batteries been depleted can be related to charging issues. Check it before replacing batteries! =)
The battery says to charge it to 100% + 2 hours and then use the controller so that it uses up the entire battery and then charge to 100% again. If you're not playing Nintendo for hours, how do you use up the battery in the controller?
Be carefull, these screws are super easy to strip even with the right tools.
Lukas Eberharter - 回复
I tried editing these instructions after I had trouble with stripping screws, but it doesn't seem to take. The issue is that these are JIS and not Phillips screws. They are VERY similar looking but a Phillips head screwdriver will strip the screws.
Isaac Webb - 回复
I tried using a Philips #00 screwdriver but it didn’t work
vincent ingrassia - 回复
Don't even think about trying Phillips. There are some other guides online that say you'll be fine, but they're wrong. Even one attempt with Phillips WILL strip these, and you will never, ever get this controller open once that happens. Even with JIS they're really hard to get out and really easy to strip.
Luke T. Allen - 回复
