跳转到主内容
Nikon Coolpix P510 Battery Removal Replacement
Brian Hulsey
Brian Hulsey2 其他贡献者
最后更新于 July 10, 2020
1 - 2 分钟
非常容易
更好的介绍
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: 步骤 1 中的图像 1,1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix P510 Battery Removal Replacement: 步骤 2 中的图像 2,2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
结论
Brian Hulsey
于03/31/15注册
1,506 声望
创作了6篇指南
团队
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G2
3 名成员
创作了12篇指南
3指南评论
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - 回复
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - 回复
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 28
总计 4,328
