跳转到主内容
Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement
你所需要的
  1. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Eject the SIM card tray: 步骤 1 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Eject the SIM card tray: 步骤 1 中的图像 2,2
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
  2. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the SIM card tray: 步骤 2 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the SIM card tray: 步骤 2 中的图像 2,2
    • Grab and remove the SIM card tray from the phone.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
  3. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Heat the edge: 步骤 3 中的图像 1,1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the edge of the back cover with the SIM card slot for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Apply a suction cup to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  5. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the right adhesive: 步骤 5 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the right adhesive: 步骤 5 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the right adhesive: 步骤 5 中的图像 3,3
    • Slide your opening pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick in at the bottom right corner to prevent the adhesive from resealing.
  6. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the bottom adhesive: 步骤 6 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the bottom adhesive: 步骤 6 中的图像 2,2
    • Insert a second opening pick into the bottom right corner.
    • Slide this opening pick along the bottom edge to the bottom left corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
  7. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the left adhesive: 步骤 7 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the left adhesive: 步骤 7 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the left adhesive: 步骤 7 中的图像 3,3
    • Insert a third opening pick into the bottom right corner.
    • Slide this opening pick along the left edge to slice the adhesive.
    • Don't worry about slicing under the camera bezel. It's separate from the back cover and will be removed later.
    • Leave the pick inserted in the top left corner to prevent the left edge from resealing.
  8. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the top adhesive: 步骤 8 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the top adhesive: 步骤 8 中的图像 2,2
    • Insert a fourth pick into the top left corner.
    • Slide the pick to the top right corner to slice the top adhesive.
  9. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice around the camera bezel: 步骤 9 中的图像 1,1
    • Slide an opening pick between the camera bezel and the back cover.
    • The back cover's adhesive is particularly strong around the camera bezel.
    • Slide the opening pick around the camera bezel to separate the back cover from the frame.
  10. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the back cover: 步骤 10 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the back cover: 步骤 10 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the back cover: 步骤 10 中的图像 3,3
    • Grab and remove the back cover by lifting it away from the phone.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  11. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Heat the camera bezel: 步骤 11 中的图像 1,1
    • Heat an iOpener and apply it to the camera bezel for two minutes.
  12. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the adhesive: 步骤 12 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the adhesive: 步骤 12 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Slice the adhesive: 步骤 12 中的图像 3,3
    • Insert an opening pick under the camera bezel.
    • Slide the pick around the perimeter of the bezel to slice the adhesive.
    • If it feels stuck, apply more heat to further loosen the adhesive.
  13. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the camera bezel: 步骤 13 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the camera bezel: 步骤 13 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the camera bezel: 步骤 13 中的图像 3,3
    • Grab and remove the camera bezel.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the camera bezel with custom-cut adhesives, follow this guide.
    • To adhere the camera bezel with tape, follow this guide.
  14. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Unfasten the motherboard cover: 步骤 14 中的图像 1,1
    • Use a Phillips screwdriver to remove the eleven 4.1 mm-long screws securing the motherboard cover.
    • If you can't find all the screws, check under any leftover adhesive residue.
  15. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Unclip the right edge: 步骤 15 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Unclip the right edge: 步骤 15 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Unclip the right edge: 步骤 15 中的图像 3,3
    • Insert a spudger between the bottom right corner of the cover and the frame.
    • Pry up to release the clips securing the cover.
    • Slide the spudger toward the top of the cover and pry to release the right edge.
  16. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the motherboard cover: 步骤 16 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the motherboard cover: 步骤 16 中的图像 2,2
    • Grip the right edge of the cover and pull it off the motherboard.
  17. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the battery: 步骤 17 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the battery: 步骤 17 中的图像 2,2
    • Use the point of a spudger to pry up the battery's press connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the display: 步骤 18 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the display: 步骤 18 中的图像 2,2
    • Use the pointed end of your spudger to pry and disconnect the display's press connector.
  19. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the antenna cable: 步骤 19 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the antenna cable: 步骤 19 中的图像 2,2
    • Use the pointed end of your spudger to pry and disconnect the white antenna cable.
    • Pry on only the metal head of the connector. Avoid lifting the cable itself as much as possible.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  20. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the board connector: 步骤 20 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the board connector: 步骤 20 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the board cable's press connector.
  21. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the upper 5G mmWave antenna: 步骤 21 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the upper 5G mmWave antenna: 步骤 21 中的图像 2,2
    • Use the pointed end of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  22. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Unfasten the motherboard: 步骤 22 中的图像 1,1
    • Use your Phillips screwdriver to remove the 3 mm-long screw securing the motherboard.
  23. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Reposition the graphite film: 步骤 23 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Reposition the graphite film: 步骤 23 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Reposition the graphite film: 步骤 23 中的图像 3,3
    • Lift and fold the graphite film off the battery and flip it onto the motherboard.
    • Use caution not to tear the film. It's adhered lightly to the battery.
  24. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the motherboard: 步骤 24 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the motherboard: 步骤 24 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the motherboard: 步骤 24 中的图像 3,3
    • Grab the motherboard from the bottom edge and lift it from its recess.
    • Be sure the loose cables don't catch on the motherboard as it's removed.
    • During reassembly, make sure no cables or connectors become trapped underneath the motherboard.
  25. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Soften the adhesive: 步骤 25 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Soften the adhesive: 步骤 25 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Soften the adhesive: 步骤 25 中的图像 3,3
    • Heat an iOpener and apply it to the antenna bracket in the upper left of the frame for two minutes.
    • Alternatively, use highly-concentrated isopropyl alcohol (over 90%) between the bracket and upper left of the frame.
  26. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the antenna bracket: 步骤 26 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the antenna bracket: 步骤 26 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Remove the antenna bracket: 步骤 26 中的图像 3,3
    • Insert the pointed end of a spudger between the right side of the 5G mmWave antenna bracket and the frame.
    • Pry up the bracket.
    • A strong metal tape holds the bracket to the frame. Work slowly to avoid tearing this adhesive tape.
    • Remove the bracket from its recess.
    • During reassembly, remove the old adhesive from the bracket and frame, then apply new adhesive.
  27. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Separate the antenna from its bracket: 步骤 27 中的图像 1,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Separate the antenna from its bracket: 步骤 27 中的图像 2,3 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Separate the antenna from its bracket: 步骤 27 中的图像 3,3
    • Use the flat end of a spudger to pry between the soft pad under the antenna's press connector and the bracket.
    • Grab and separate the 5G mmWave antenna from the bracket.
  28. Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: 步骤 28 中的图像 1,2 Motorola Moto G Stylus 5G (2022) Upper 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: 步骤 28 中的图像 2,2
    • Use the point of your spudger to pry and disconnect the antenna's press connector.
    • Remove the cable.
    • With the cable removed, the antenna is all that remains.
结论
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
3等其他人完成本指南。
Clay Eickemeyer
于09/19/22注册
67,432 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,432篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 38
总计 814
