跳转到主内容
Motorola Moto G Play (2021) Motherboard Replacement
你所需要的
  1. Motorola Moto G Play (2021) Motherboard Replacement, Remove the SIM card tray: 步骤 1 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the SIM card tray: 步骤 1 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the SIM card tray: 步骤 1 中的图像 3,3
    • Insert a SIM card eject tool or a straightened paperclip into the hole adjacent to the SIM card tray.
    • Press firmly to eject the tray.
    • The SIM card may fall out.
    • Grab and remove the SIM card tray from the phone.
    • Reinsert the SIM card tray with the SIM card recess facing the screen.
  2. Motorola Moto G Play (2021) Motherboard Replacement, Heat the left edge: 步骤 2 中的图像 1,1
    • Discharge your battery to 25% or lower and power off your phone before you begin.
    • Heat an iOpener and apply it to the left edge of the cover for two minutes.
    • A hair dryer or heat gun may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Moto G Play (2021) Motherboard Replacement, Insert an opening pick: 步骤 3 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Insert an opening pick: 步骤 3 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Insert an opening pick: 步骤 3 中的图像 3,3
    • Apply a suction cup to the back cover, as close to the center of the left edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the cover and the frame.
    • Insert an opening pick into the gap.
  4. Motorola Moto G Play (2021) Motherboard Replacement, Slice the right adhesive: 步骤 4 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Slice the right adhesive: 步骤 4 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Slice the right adhesive: 步骤 4 中的图像 3,3
    • Slide your opening pick back and forth along the left edge to slice through the adhesive.
    • Leave the pick in at the bottom left corner to prevent the adhesive from resealing.
  5. Motorola Moto G Play (2021) Motherboard Replacement, Slice the bottom adhesive: 步骤 5 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Slice the bottom adhesive: 步骤 5 中的图像 2,2
    • Insert and slide a second opening pick to the bottom right corner to slice through the adhesive.
    • Leave the pick inserted to prevent the bottom edge from resealing.
    • Repeat this process for the right and top edges of the cover.
  6. Motorola Moto G Play (2021) Motherboard Replacement, Dislodge the fingerprint reader: 步骤 6 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Dislodge the fingerprint reader: 步骤 6 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Dislodge the fingerprint reader: 步骤 6 中的图像 3,3
    • The fingerprint reader is connected to the motherboard by a fragile cable. You must free it before pulling the cover off.
    • Grab and lift the bottom edge of the cover.
    • As you lift the back cover, press and unstick the fingerprint reader from it.
  7. Motorola Moto G Play (2021) Motherboard Replacement, Remove the back cover: 步骤 7 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the back cover: 步骤 7 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the back cover: 步骤 7 中的图像 3,3
    • Grab and remove the back cover.
    • If your back cover is still sticking to the frame, slide the pick around the edges of the phone to slice through any remaining adhesive.
    • Reassembly notes:
    • This is a good point to test your phone before sealing it up. Follow this guide to perform a hardware test. Be sure to power your phone back down completely before you continue working.
    • To adhere the back cover with custom-cut adhesives, follow this guide.
    • To adhere the back cover with tape, follow this guide.
  8. Motorola Moto G Play (2021) Motherboard Replacement, Reposition the fingerprint reader: 步骤 8 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Reposition the fingerprint reader: 步骤 8 中的图像 2,2
    • Flip the fingerprint reader to the left, away from the phone.
    • Don't fold or sharply bend the ribbon cable.
  9. Motorola Moto G Play (2021) Motherboard Replacement, Unfasten the motherboard cover: 步骤 9 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Unfasten the motherboard cover: 步骤 9 中的图像 2,2
    • Use your Phillips screwdriver to remove the twelve 3.9 mm-long screws securing the motherboard cover.
  10. Motorola Moto G Play (2021) Motherboard Replacement, Pry the motherboard cover: 步骤 10 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Pry the motherboard cover: 步骤 10 中的图像 2,2
    • Insert the pointed end of a spudger between the bottom right corner of the motherboard cover and the frame.
    • Pry the cover upward until you can grab it with your fingers.
  11. Motorola Moto G Play (2021) Motherboard Replacement, Remove the motherboard cover: 步骤 11 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Remove the motherboard cover: 步骤 11 中的图像 2,2
    • Grab the bottom edge of the motherboard cover and remove it from the frame.
  12. Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the battery: 步骤 12 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the battery: 步骤 12 中的图像 2,2
    • Use the pointed end of your spudger to pry and disconnect the battery's press connector.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  13. Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the fingerprint reader: 步骤 13 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the fingerprint reader: 步骤 13 中的图像 2,2
    • Use the pointed end of your spudger to pry and disconnect the fingerprint reader's press connector.
    • The gold arrow indicates the direction to pry from.
  14. Motorola Moto G Play (2021) Motherboard Replacement, Remove the fingerprint reader: 步骤 14 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Remove the fingerprint reader: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use your fingers or tweezers to remove the fingerprint reader.
    • Be careful while handling the fragile ribbon cable.
  15. Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the antenna cables: 步骤 15 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the antenna cables: 步骤 15 中的图像 2,2
    • Use the pointed end of your spudger to pry and disconnect the gray antenna cable.
    • Pry on the metal head of the connector only. Avoid lifting the cable itself as much as possible.
    • During reassembly, these can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  16. Motorola Moto G Play (2021) Motherboard Replacement: 步骤 16 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement: 步骤 16 中的图像 2,2
    • Repeat the previous step for the black antenna cable.
  17. Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the board cable: 步骤 17 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the board cable: 步骤 17 中的图像 2,2
    • Use the pointed end of your spudger to pry and disconnect the board cable's press connector.
  18. Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the display: 步骤 18 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Disconnect the display: 步骤 18 中的图像 2,2
    • Use the pointed end of your spudger to pry and disconnect the display's press connector.
  19. Motorola Moto G Play (2021) Motherboard Replacement, Unfasten the motherboard: 步骤 19 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Unfasten the motherboard: 步骤 19 中的图像 2,2
    • Use your Phillips screwdriver to remove the two 2.5 mm-long screws securing the motherboard.
  20. Motorola Moto G Play (2021) Motherboard Replacement, Lift the motherboard: 步骤 20 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Lift the motherboard: 步骤 20 中的图像 2,2
    • Insert the pointed end of your spudger between the bottom left edge of the motherboard and the frame.
    • Lift the motherboard from its recess.
    • Be sure the loose cables don't catch on the motherboard as it's removed.
  21. Motorola Moto G Play (2021) Motherboard Replacement, Remove the motherboard: 步骤 21 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Remove the motherboard: 步骤 21 中的图像 2,2
    • Grab the motherboard by its bottom corners and remove it.
    • During reassembly, make sure no cables or connectors become trapped underneath the motherboard.
  22. Motorola Moto G Play (2021) Motherboard Replacement, Clean the thermal paste: 步骤 22 中的图像 1,2 Motorola Moto G Play (2021) Motherboard Replacement, Clean the thermal paste: 步骤 22 中的图像 2,2
    • Follow this guide to remove excess thermal paste and prepare the frame and motherboard for reassembly.
  23. Motorola Moto G Play (2021) Motherboard Replacement, Remove the depth camera: 步骤 23 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the depth camera: 步骤 23 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the depth camera: 步骤 23 中的图像 3,3
    • Use the pointed end of your spudger to pry and disconnect the depth camera's press connector.
    • The camera may eject from the motherboard. Work slowly to avoid losing it.
    • Remove the camera.
  24. Motorola Moto G Play (2021) Motherboard Replacement, Remove the front-facing camera: 步骤 24 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the front-facing camera: 步骤 24 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the front-facing camera: 步骤 24 中的图像 3,3
    • Use the pointed end of your spudger to pry and disconnect the front-facing camera's press connector.
  25. Motorola Moto G Play (2021) Motherboard Replacement, Remove the 3.5 mm jack gasket: 步骤 25 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the 3.5 mm jack gasket: 步骤 25 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the 3.5 mm jack gasket: 步骤 25 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use your fingers or a pair of tweezers to remove the gasket from the 3.5 mm jack.
  26. Motorola Moto G Play (2021) Motherboard Replacement, Remove the main camera: 步骤 26 中的图像 1,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the main camera: 步骤 26 中的图像 2,3 Motorola Moto G Play (2021) Motherboard Replacement, Remove the main camera: 步骤 26 中的图像 3,3
    • Use the pointed end of your spudger to pry and disconnect the main camera's press connector.
  27. Motorola Moto G Play (2021) Motherboard Replacement: 步骤 27 中的图像 1,1
    • The motherboard is all that remains.
结论
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Clay Eickemeyer
于09/19/22注册
70,402 声望
创作了453篇指南
团队
iFixit iFixit 的会员
Staff
140 名成员
创作了18,077篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 26
总计 864
