跳转到主内容
加入维修社区 - 创建账户
Moto Z Display Assembly Replacement
你所需要的
  1. Moto Z Display Assembly Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
    询问修复机器人
    添加评论
  2. Moto Z Display Assembly Replacement: 步骤 2 中的图像 1,2 Moto Z Display Assembly Replacement: 步骤 2 中的图像 2,2
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
    询问修复机器人
    添加评论
  3. Moto Z Display Assembly Replacement: 步骤 3 中的图像 1,3 Moto Z Display Assembly Replacement: 步骤 3 中的图像 2,3 Moto Z Display Assembly Replacement: 步骤 3 中的图像 3,3
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
    询问修复机器人
    添加评论
  4. Moto Z Display Assembly Replacement: 步骤 4 中的图像 1,3 Moto Z Display Assembly Replacement: 步骤 4 中的图像 2,3 Moto Z Display Assembly Replacement: 步骤 4 中的图像 3,3
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
    询问修复机器人
    添加评论
  5. Moto Z Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
    询问修复机器人
    添加评论
  6. Moto Z Display Assembly Replacement: 步骤 6 中的图像 1,1
    询问修复机器人
    添加评论
  7. Moto Z Display Assembly Replacement: 步骤 7 中的图像 1,2 Moto Z Display Assembly Replacement: 步骤 7 中的图像 2,2
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  8. Moto Z Display Assembly Replacement: 步骤 8 中的图像 1,3 Moto Z Display Assembly Replacement: 步骤 8 中的图像 2,3 Moto Z Display Assembly Replacement: 步骤 8 中的图像 3,3
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
    询问修复机器人
    添加评论
  9. Moto Z Display Assembly Replacement: 步骤 9 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
    询问修复机器人
    添加评论
  10. Moto Z Display Assembly Replacement: 步骤 10 中的图像 1,3 Moto Z Display Assembly Replacement: 步骤 10 中的图像 2,3 Moto Z Display Assembly Replacement: 步骤 10 中的图像 3,3
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
    询问修复机器人
    添加评论
  11. Moto Z Display Assembly Replacement: 步骤 11 中的图像 1,2 Moto Z Display Assembly Replacement: 步骤 11 中的图像 2,2
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
    询问修复机器人
    添加评论
  12. Moto Z Display Assembly Replacement: 步骤 12 中的图像 1,3 Moto Z Display Assembly Replacement: 步骤 12 中的图像 2,3 Moto Z Display Assembly Replacement: 步骤 12 中的图像 3,3
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
    添加评论
  13. Moto Z Display Assembly Replacement: 步骤 13 中的图像 1,3 Moto Z Display Assembly Replacement: 步骤 13 中的图像 2,3 Moto Z Display Assembly Replacement: 步骤 13 中的图像 3,3
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
    询问修复机器人
    添加评论
  14. Moto Z Display Assembly Replacement: 步骤 14 中的图像 1,2 Moto Z Display Assembly Replacement: 步骤 14 中的图像 2,2
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
    询问修复机器人
    添加评论
  15. Moto Z Display Assembly Replacement: 步骤 15 中的图像 1,2 Moto Z Display Assembly Replacement: 步骤 15 中的图像 2,2
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
    添加评论
  16. Moto Z Display Assembly Replacement, Fingerprint Sensor: 步骤 16 中的图像 1,2 Moto Z Display Assembly Replacement, Fingerprint Sensor: 步骤 16 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to peel off any tape on the home button connector and home button
    询问修复机器人
    添加评论
  17. Moto Z Display Assembly Replacement: 步骤 17 中的图像 1,2 Moto Z Display Assembly Replacement: 步骤 17 中的图像 2,2
    • Use the point of a spudger to flip up the home button connector's lock.
    询问修复机器人
    添加评论
  18. Moto Z Display Assembly Replacement: 步骤 18 中的图像 1,2 Moto Z Display Assembly Replacement: 步骤 18 中的图像 2,2
    • Use tweezers to carefully pull the home button cable straight out of the socket.
    询问修复机器人
    添加评论
  19. Moto Z Display Assembly Replacement: 步骤 19 中的图像 1,1
    • Remove the home button.
    询问修复机器人
    添加评论
结论
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto Z Answers community for troubleshooting help.
取消:我没有完成这个指南。
19等其他人完成本指南。
Arthur Shi
于01/03/18注册
343,709 声望
创作了915篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了28,236篇指南
14指南评论
Do you ship to India?
gsriram72 - 回复 分享
Watch the youtube video it’s a lot better also instead of sending a sticker that connects the phone and the screen they should’ve added adhesive to the new screen.
Jonathan Davila - 回复 分享
Hi Jonathan,
Unlike aftermarket screens that may have adhesive pre-attached, we are an authorized Motorola reseller and sell OEM Motorola parts. In this case, the OEM screen comes without adhesive pre-attached.
Arthur Shi - 回复 分享
For the most part this was a helpful guide, but what about the flash? When following the directions the flash comes off with the screen/digitizer, and it appears to have happened to the author as well. There is no mention or help in reattaching this component or needing to purchase a new flash component prior to beginning the repair. It will be too late for me, but any insight might help others.
Joe Wiltjer - 回复 分享
Hey Joe,
You’re right—depending on the part you order, you may need to transfer the flash lens from your original back cover to the replacement part. This involves prying the original off and sticking it back onto the replacement cover. I’ll add a note to one of the steps.
Arthur Shi - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 67
总计 10,453
