跳转到主内容
Moto Z Battery Replacement
你所需要的
  1. Moto Z Battery Replacement, Display Assembly: 步骤 1 中的图像 1,1
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
  2. Moto Z Battery Replacement: 步骤 2 中的图像 1,2 Moto Z Battery Replacement: 步骤 2 中的图像 2,2
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
  3. Moto Z Battery Replacement: 步骤 3 中的图像 1,3 Moto Z Battery Replacement: 步骤 3 中的图像 2,3 Moto Z Battery Replacement: 步骤 3 中的图像 3,3
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
  4. Moto Z Battery Replacement: 步骤 4 中的图像 1,3 Moto Z Battery Replacement: 步骤 4 中的图像 2,3 Moto Z Battery Replacement: 步骤 4 中的图像 3,3
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
  5. Moto Z Battery Replacement: 步骤 5 中的图像 1,1
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
  6. Moto Z Battery Replacement: 步骤 6 中的图像 1,1
  7. Moto Z Battery Replacement: 步骤 7 中的图像 1,2 Moto Z Battery Replacement: 步骤 7 中的图像 2,2
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
  8. Moto Z Battery Replacement: 步骤 8 中的图像 1,3 Moto Z Battery Replacement: 步骤 8 中的图像 2,3 Moto Z Battery Replacement: 步骤 8 中的图像 3,3
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
  9. Moto Z Battery Replacement: 步骤 9 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
  10. Moto Z Battery Replacement: 步骤 10 中的图像 1,3 Moto Z Battery Replacement: 步骤 10 中的图像 2,3 Moto Z Battery Replacement: 步骤 10 中的图像 3,3
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
  11. Moto Z Battery Replacement: 步骤 11 中的图像 1,2 Moto Z Battery Replacement: 步骤 11 中的图像 2,2
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
  12. Moto Z Battery Replacement: 步骤 12 中的图像 1,3 Moto Z Battery Replacement: 步骤 12 中的图像 2,3 Moto Z Battery Replacement: 步骤 12 中的图像 3,3
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
  13. Moto Z Battery Replacement: 步骤 13 中的图像 1,3 Moto Z Battery Replacement: 步骤 13 中的图像 2,3 Moto Z Battery Replacement: 步骤 13 中的图像 3,3
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
  14. Moto Z Battery Replacement: 步骤 14 中的图像 1,2 Moto Z Battery Replacement: 步骤 14 中的图像 2,2
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
  15. Moto Z Battery Replacement: 步骤 15 中的图像 1,2 Moto Z Battery Replacement: 步骤 15 中的图像 2,2
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
  16. Moto Z Battery Replacement, Battery: 步骤 16 中的图像 1,3 Moto Z Battery Replacement, Battery: 步骤 16 中的图像 2,3 Moto Z Battery Replacement, Battery: 步骤 16 中的图像 3,3
    • Use tweezers to peel the black tape securing the battery to the frame.
    • If your replacement battery did not come with this piece of tape, transfer it from the old battery to the replacement battery.
  17. Moto Z Battery Replacement: 步骤 17 中的图像 1,1
    • Lay a heated iOpener on the back of the phone as shown for as least 90 seconds.
  18. Moto Z Battery Replacement: 步骤 18 中的图像 1,3 Moto Z Battery Replacement: 步骤 18 中的图像 2,3 Moto Z Battery Replacement: 步骤 18 中的图像 3,3
    • Using a pair of tweezers or your fingers, grab the black battery pull tab and slowly pull it upwards until the corner is loose.
    • Do not fully remove the battery as it is still connected by a flex cable.
  19. Moto Z Battery Replacement: 步骤 19 中的图像 1,2 Moto Z Battery Replacement: 步骤 19 中的图像 2,2
    • Follow this step only if your battery tab has broken. Otherwise, skip to the next step.
    • Insert a spudger into the bottom edge of the battery and slowly pry the corner up.
  20. Moto Z Battery Replacement: 步骤 20 中的图像 1,3 Moto Z Battery Replacement: 步骤 20 中的图像 2,3 Moto Z Battery Replacement: 步骤 20 中的图像 3,3
    • Carefully swing the battery towards the right edge.
    • Lay the battery flat against the work surface while taking care not to strain the battery cable.
  21. Moto Z Battery Replacement: 步骤 21 中的图像 1,3 Moto Z Battery Replacement: 步骤 21 中的图像 2,3 Moto Z Battery Replacement: 步骤 21 中的图像 3,3
    • Use the point of a spudger to pry up the battery connector bracket.
    • The bracket is held in place by some adhesive and tabs.
    • Remove the battery connector bracket.
    • When you reinstall the bracket, make sure to align the tabs on the bracket with the indents on the left edge of the frame.
  22. Moto Z Battery Replacement: 步骤 22 中的图像 1,2 Moto Z Battery Replacement: 步骤 22 中的图像 2,2
    • Using the point of a spudger, pry up the battery connector from its socket.
  23. Moto Z Battery Replacement: 步骤 23 中的图像 1,1
    在这个步骤中使用的工具:
    Tesa 61395 Tape
    $5.99
    购买
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery:
    • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Apply pre-cut adhesive strips or double-sided tape to the exposed, silver part of the battery compartment, not on the black foam layer.
    • Press the battery firmly into place for 5-10 seconds.
结论
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto Z Answers community for troubleshooting help.
31等其他人完成本指南。
Arthur Shi
于01/03/18注册
252,897 声望
创作了526篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,820篇指南
27条评论
Kindly link me to the suitable adhesive tape for sticking back the screen…
Thank you
Anwesh Maile - 回复
Hi Anwesh,
You can use Tesa tape for that purpose.
Arthur Shi -
I have a Moto Z Droid from Verizon. You have instruction for the Moto Z and Moto Z Droid Force. Battery replacement on the Droid Force is much easier. How do I know which one I have?
Budbradley - 回复
Hi Budbradley,
According to Phonearena, it looks like one easy way to tell is the rear camera:
The Z has a 13MP camera, while the Z Force Droid has a 21MP rear camera.
The built-in internal storage are also different:
The Z has 32GB while the Z Force Droid has 64GB.
Hopefully you can check your specs with those and figure out which version you have.
Arthur Shi -
The hardest step in this guide is when you remove adhesive glue behind the LCD panel.
Second is clean residue glue [For this i use lint-free cloth soak with alcohol and rub on glue]
One more note - Moto original battery is su..k. Mine is degrade in 6 moths.
Rawin Juangrat - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 28
过去 30 天: 115
总计 43,706
