跳转到主内容
Microsoft Surface Pro 3
Erik Snyder
Erik Snyder6 其他贡献者
最后更新于 May 3, 2021
1 - 2 小时
非常困难
指导会教你如果安全的移除你的耳机接口。要先移除你的显示屏和触控板在开始拆卸你的耳机接口
你所需要的
配件
工具
查看更多...
  1. Microsoft Surface Pro 3, 显示屏: 步骤 1 中的图像 1,2 Microsoft Surface Pro 3, 显示屏: 步骤 1 中的图像 2,2
    • 开始之前,请将 Surface Pro 的电池电量放电至 25% 以下。如果在维修过程中意外损坏,充电的锂离子电池可能会起火或爆炸。
    • 显示屏与设备边框紧密粘合。
    • 要移除显示屏,首先要加热软化粘合剂。可以使用热垫、热风枪或 iOpener。如沒有以上工具,也可以使用吹风机。
    • 使用热风枪时要小心,因为过热可能会永久损坏显示屏和电池。
    • 稳步均匀地加热显示屏四周,直到热到无法触摸为止,并尽量将温度维持几分钟。
    I just replaced both my screen and battery. It took four hours and a couple of wrong turns but I was successful learning what to do next time. However, I am not sure I would do it again.
    It takes more heat than one imagines - all most too much and made me queasy fearing I was going to damage something. I would say it actually too hot and likely to damage something so be careful and do not prolong the removal. To get started I used a glass top warming/buffet heating tray set to about 200 degrees.  I turned the surface pro glass side down before turning it one so it would heat gradually with the tray. I let it heat for 15 minutes. In end, I am not sure it helped or not by starting this way.  This was not an easy removal so I shudder to think how worse it would have been if this didn’t help. I used a variable heat gun for the remaining steps. My screen was broken so breaking it further while nerve racking was not going to be catastrophic.
    michael jones - 回复
    I attempted battery replacement, but during disassembly, i damaged the display by inserting the picks to far, and separating the display circuitry from the glass.
    I used a Milwaukee precision hot tool model 1400, which has only a fixed heat setting, but it worked perfectly to soften the adhesive.
    (I was very careful to heat the entire glass panel by playing the heat gun over the entire surface so that it would expand uniformly.
    Robert Gerlach - 回复
    I just broke mine during the heating process as well…. The glue at the corner was so strong that I cant even slip a blade into the edge… Then when keep applying heat using a hair dryer at low tempreture the glass expanded too much and broke……
    C Y Wong - 回复
    If you have never done this repair, YOU WILL SHATTER THE SCREEN! I've repaired dozens of these over the last several years for my client's and I still shatter them. It's a 98% probability that you will break the glass; it's very thin and shatters easily. Be prepared.
    Gregg Stanley - 回复
  2. Microsoft Surface Pro 3: 步骤 2 中的图像 1,2 Microsoft Surface Pro 3: 步骤 2 中的图像 2,2
    • 用吸盘或iSlack拉起玻璃,在玻璃和金属框之间形成一个小缝隙。
    • 如果显示屏严重破裂,吸盘可能无法吸附。首先在显示屏上覆盖一层胶带可能会有帮助。或者,你也可以将吸盘粘在显示屏上。
    • 小心地将三角撬片插入屏幕和设备之间的缝隙中,切割粘合剂。
    • 在显示屏的侧面和底部滑动三角撬片以切割粘合剂。必要时再加热。
    • 小心操作—显示屏的玻璃很薄,如果用力很容易破裂。
    • Wi-Fi 天线粘在屏幕上沿的边框下面(在摄像头的两侧),很容易损坏。分离顶边时要格外小心,必要时要多加热。
    Be very very careful!! Don’t cut yourself. Wear gloves.
    Vincent van Mens - 回复
    Wear eye protection too!
    Zach - 回复
  3. Microsoft Surface Pro 3: 步骤 3 中的图像 1,3 Microsoft Surface Pro 3: 步骤 3 中的图像 2,3 Microsoft Surface Pro 3: 步骤 3 中的图像 3,3
    • 继续用热风枪加显示屏的各个部分。
    • 使用热风枪加热显示屏并且同时使用三角塑料撬片小心的撬开你的屏幕。
    • 显示屏极度容易破碎,小心处理破碎的玻璃。
    I used an inexpensive variable heat gun with a dial. It was perfect. My fixed temperature gun would have ruined it. There are two small vents on either side of the screen near the top. Start there and work down on each side. I didn’t have opening picks to keep the glass separated from the body. So, I used blank Cards Against Humanity I found lying around.
    I watched two popular videos. Neither helped and were no better than these instructions. In one video, the guy heats and smashes his way around the display with metal tool. Mistake! Don’t do this even if the screen is broken. This causes glass shards to go everywhere and will force you to replace the adhesive before installing a new screen. You can’t reuse adhesive if it is full of glass. Another video uses a heat gun one side at a time and simply sliding a pick along the edge working around the Surface. This didn’t work. The person had already removed the screen once before and started the second removal before the video.
    michael jones - 回复
    CAUTION: if you insert the picks too far, you risk damaging the display (separating the glass from the display circuitry).
    The display circuitry is 14 mm from the side edges, 10 mm from the top edge, and 6 mm from the bottom edge.
    Robert Gerlach - 回复
    thanks a lot for your comment
    philrillh -
  4. Microsoft Surface Pro 3: 步骤 4 中的图像 1,2 Microsoft Surface Pro 3: 步骤 4 中的图像 2,2
    • 小心提起已分离的屏幕。注意不要伤到连接线。
    This guide misses a CRUCIAL NOTE on this step.
    On this step, from Picture 1 to Picture 2 the device is rotated so the Windows logo on the glass is actually on the left hand side.
    You *must* rotate the device otherwise you will risk damaging the cables, as it folds open like a book.
    Len Demby, Jr. - 回复
    Pain in the ass! One has to wonder why they couldn’t use magnetic connections instead of this goo, black thing that even to replace is so %#*@ annoying to say the least! After trying to remove a broken screen I didn’t even use the adhesive strips. I used the ones I had there and to be frank it’s better since:
    a) I couldn’t get the new screen properly aligned and to fit to perfection even though the touch works flawlessly (w/ some adhesive tape on the top to hide the gaps) and
    b) who knows? you may as well need to reopen it again. Hopefully not.Hopefully it will be easier. Hopefully never again!!!
    P.S.:
    Iraklis - 回复
  5. Microsoft Surface Pro 3: 步骤 5 中的图像 1,2 Microsoft Surface Pro 3: 步骤 5 中的图像 2,2
    • 卸下固定电池的3 mm T3梅花螺丝,并断开电池连接器。
    • 小心不要弄丢连接线和接头之间的小型连接板。
  6. Microsoft Surface Pro 3: 步骤 6 中的图像 1,3 Microsoft Surface Pro 3: 步骤 6 中的图像 2,3 Microsoft Surface Pro 3: 步骤 6 中的图像 3,3
    • 移除显示屏连接线上的 4mm T3 梅花螺丝。
    • 提起连接器以断开排线连接。
    It's always best to disconnect the battery before disconnecting the display cable. Ensuring there is no power to the device will also ensure you don't damage the backlight components when disconnecting the display. You should also make sure to reattach the display cable before reattaching the battery cable when putting it back together.
    KCrepairguy - 回复
    There is also a tiny little board between the ribbon cable and motherboard. Be sure not to lose it!!! If you do the part is 1631 LCD Contact Shield Plate.
    Joseph Neilson - 回复
    You’ll notice a spring on the back of your old screen. The new screens don’t have that spring so it will need to be transferred over by the heat gun trick.
    Thierry Plouchart - 回复
    The instructions do not mention the bridge connectors under the connectors - tiny little rectangle boards with gold connector dots. There is one under the battery connector and under the display connector. It is sandwiched in between the board and the connector. You may not even notice the bridge connectors. In fact the pictures here with the cable connectors off are showing the bridge connectors under the cable connectors still lying on the motherboard. Go ahead and remove the bridge connectors with tweezers. These connectors are just lying on the motherboard and WILL FALL OFF getting lost without noticing it. The cable connectors do not work without the bridge connectors installed. Good news is the connectors are keyed and fit only one way.
    BTW: Both screws on the battery and display connector were T3’s and the same size.
    michael jones - 回复
    Hi!. What’s the name of the band connector and what’s the name of the connector in both sides?
    Nicolás Rearte - 回复
  7. Microsoft Surface Pro 3: 步骤 7 中的图像 1,3 Microsoft Surface Pro 3: 步骤 7 中的图像 2,3 Microsoft Surface Pro 3: 步骤 7 中的图像 3,3
    • 抓住银色连接器的橘黄色连接线
    • 小心地拔出橘黄色的连接线直到脱离连接器
    • 屏幕已完全断开连接
    • 用于替换的屏幕上可能没有所有需要安装回去的零件。保存好拆下的屏幕上所有的零件,如果需要的话将其替换到新屏幕上。
  8. Microsoft Surface Pro 3, 耳机接口: 步骤 8 中的图像 1,2 Microsoft Surface Pro 3, 耳机接口: 步骤 8 中的图像 2,2
    • 移除1个 4mm T5 螺丝
    • 移除4个 4mm T3 螺丝
    • 移除1个 7mm T3 螺丝
  9. Microsoft Surface Pro 3: 步骤 9 中的图像 1,1
    • 移除4mm螺母
  10. Microsoft Surface Pro 3: 步骤 10 中的图像 1,2 Microsoft Surface Pro 3: 步骤 10 中的图像 2,2
    • 使用塑料Opening工具移除黑色零件
  11. Microsoft Surface Pro 3: 步骤 11 中的图像 1,1
    • 小心的移除灰色耳机接口
  12. Microsoft Surface Pro 3: 步骤 12 中的图像 1,1
    • 使用金属撬棒移除设备中的黑色连接线
  13. Microsoft Surface Pro 3: 步骤 13 中的图像 1,1
    • 移除2个4mm T3 六角螺丝
  14. Microsoft Surface Pro 3: 步骤 14 中的图像 1,2 Microsoft Surface Pro 3: 步骤 14 中的图像 2,2
    • 使用金属撬棒完成耳机接口的移除
结论
跟随说明反向安装你的设备
4等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
CoikVollin正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Erik Snyder
于10/01/15注册
5,387 声望
创作了5篇指南
团队
Cal Poly, Team 12-18, Maness Fall 2015 Cal Poly, Team 12-18, Maness Fall 2015 的会员
CPSU-MANESS-F15S12G18
5 名成员
创作了31篇指南
1指南评论
Very good instructions. But where is the difference between Headphone Jack Assembly with P/N
0801-35U00QS, 0801-35U01QS and 0801-2W900QS? On some of them is also X894488-001 printed in an extra row.
Daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 44
总计 7,476
