跳转到主内容
Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement
Spencer Day
Spencer Day 另一个贡献者
最后更新于 February 22, 2025
20 - 30 分钟
中等
特色指南
Follow this guide to replace or upgrade the SSD in your Microsoft Surface Laptop 7 (13.8‑inch).
Before starting this repair, read through Microsoft's guide on best practices for SSD removal.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Prepare your laptop for disassembly: 步骤 1 中的图像 3,3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Flip your laptop over: 步骤 2 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Flip your laptop over: 步骤 2 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Flip your laptop over: 步骤 2 中的图像 3,3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the feet: 步骤 3 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the feet: 步骤 3 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the feet: 步骤 3 中的图像 3,3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case screws: 步骤 4 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case screws: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Detach the lower case: 步骤 5 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Detach the lower case: 步骤 5 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Detach the lower case: 步骤 5 中的图像 3,3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 6 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 6 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 6 中的图像 3,3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case: 步骤 7 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case: 步骤 7 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the lower case: 步骤 7 中的图像 3,3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Disconnect the battery: 步骤 8 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Disconnect the battery: 步骤 8 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Disconnect the battery: 步骤 8 中的图像 3,3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 9 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 9 中的图像 2,2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 10 中的图像 1,2 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 10 中的图像 2,2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Peel up the SSD tape: 步骤 11 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Peel up the SSD tape: 步骤 11 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Peel up the SSD tape: 步骤 11 中的图像 3,3
    • Heat an iOpener and lay it on the SSD for one minute to heat the tape on its left edge.
    • Alternatively, you can use a hair dryer to lightly heat the tape.
  12. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 12 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 12 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 12 中的图像 3,3
    • Carefully insert the point of a spudger under the SSD tape and lift until you can grip the tape with your fingers.
    • Be careful not to tear the tape, since you'll reuse it during reassembly.
    • Use your fingers to gently peel the tape from the SSD.
    • You don't need to fully remove the tape, it just needs to be off the SSD.
  13. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the SSD: 步骤 13 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the SSD: 步骤 13 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement, Remove the SSD: 步骤 13 中的图像 3,3
    • Use a Torx Plus 5IP screwdriver to remove the 2.9 mm‑long screw securing the SSD.
    • With the screw removed, the SSD may pop up at a slight angle.
    • During reassembly, gently hold the SSD down while installing its screw.
  14. Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 14 中的图像 1,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 14 中的图像 2,3 Microsoft Surface Laptop 7 (13.8-inch) SSD Replacement: 步骤 14 中的图像 3,3
    • Grip the SSD by its edges near the screw notch and pull it straight out of its socket.
    • During reassembly, make sure the tape is completely out of the way and insert the SSD at a slight downward angle into its socket.
    • The SSD is notched so you can only insert it in the correct orientation.
结论
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
Spencer Day
于09/14/22注册
94,632 声望
创作了662篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,418篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 118
过去 30 天: 539
总计 3,091
