简介
This guide shows how to remove and replace a worn out battery in your Meta Quest 2 headset.
The battery is positioned above the screen and lens assembly and requires significant disassembly in order to reach it.
Note: You'll need a long PH00 bit or a dedicated PH00 screwdriver to remove some recessed screws.
你所需要的
Hold the power button for three seconds to fully turn off your headset.
Grasp and pull on the nose section of the facial interface to unclip it from the headset.
Use your fingers to grasp the right strap near the headset.
Peel the right strap away from the headset arm to unclip it.
Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
Set the trim down on your work surface, making sure not to strain the cable.
Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
Use a spudger to press the lock tab down towards the cable to lock it in place.
Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
One recessed in the top-left corner
One recessed in the top-right corner
Three along the lower edge
Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
Pry with the opening pick to release the front cover clips.
在这个步骤中使用的工具:Tweezers$4.99
Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
Lift the antenna connector straight up to disconnect it.
Guide the antenna cable out of its metal clip holding it in place.
Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
One 4.4 mm‑long screw
Two 2.3 mm‑long screws
Use a spudger to pry up and disconnect the battery press connector from the motherboard.
Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
Four 4.4 mm‑long screws
Two 4.8 mm‑long screws
Two 10.7 mm‑long screws
Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
Remove the two screws securing the fan assembly to the headset:
One 4.4 mm‑long Phillips screw
One 3.6 mm‑long Torx T2 screw
Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
Two speaker connectors
Seven ZIF connectors
Two press connectors
One antenna connector
Use tweezers to gently peel the black tape covering the two top flex cables.
Remove the five screws securing the motherboard to the headset:
Four 3.8 mm‑long Phillips screws
One 6 mm‑long 3.5 mm hex standoff screw
Peel and remove the black tape covering the antenna cable.
Grasp the screen and lens assembly with your fingers.
Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
Remove the screen and lens assembly.
Three cables along the top edge—two flex cables and one LED flex cable
Two cables in the top right corner—the battery connector and an antenna cable
Two cables along the right edge—an antenna cable and a wide flex cable
Two flex cables along the bottom edge
Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
Use a Phillips screwdriver to remove the six 4.5 mm‑long screws securing the battery to the outer shell:
Two along the front edge
Four along the back edge
Slide an opening pick under the face sensor interconnect cable to loosen the adhesive securing it to the battery.
Remove the sensor interconnect cable.
For optimal performance, after completing this guide, calibrate your newly installed battery.
另外一个人完成了本指南。
